How long for a front seal change?
I was quoted under $300 for the whole job and truck was in garage for 2 days already.wont have truck till monday. they are putting a wear sleeve on crank because it has a groove. should it take 2 days?
$300 for a front seal change is a fair price..
Take two days? If it took two days then labor would be around a $1000.
Shops don't know exactly when a tech will free up sometimes so they stack them with plenty of work and the smaller jobs are fitted in here and there.
Overall its probably a 2-3 hour job give or take, also depends on how many parts they take off to get to the front seal.
true. i bet its a special tool to install wear sleeve otherwise id do it myself. I wonder if rad needs to be pulled? or just get at it from underneath
No special tool needed, the new seal comes with a cheap installation sleeve. You have to pull the intercooler, radiator, harmonic balancer, and timing cover. Replace the seal and reassemble using RTV sealant on the timing cover. It could be done in 3-4 hrs probably for a moderate level mechanic, it took me a whole day, but I am super slow and **** about everything. Jay
GOT BOOST is right, no special tools. I tapped my sleeve on with a small hammer and just be gentle. It took me 7 hrs just taking my time, looking at everything and taking my breaks.
sootnsmoke
07-17-2011 06:31 AM
92smokin blacky
01-04-2011 12:43 AM
RTillery
02-07-2009 08:46 AM
dieseljerk
07-08-2004 07:23 AM
