How high is too high?
Old 04-20-2006, 01:18 PM
SOhappy's Avatar
Originally Posted by realsquash
Are you saying you got 34psi stock but just with a boost elbow? I don't think so.
I've seen it top out from the low 20s stock, to 30 psi with just the addition of a boost elbow.
As far as EGTs, my limited experience has been that as long as I keep it below 3100 rpm the EGTs don't climb over 1400°.
Old 04-20-2006, 01:27 PM
v8440's Avatar
I had a stone stock, as in stock down to the paper air filter element, 04.5 dually. It would flash up to about 34 pounds, then settle down at about 29 or 30. The 03's probably don't run as much boost, as they don't fuel as hard either.
Old 04-20-2006, 01:35 PM
ptgarcia's Avatar
When ordering my gauges everyone told me to get the 60 p.s.i. boost because even on a stock '06 you can exceed 30 p.s.i.
Old 04-20-2006, 03:03 PM
realsquash's Avatar
That's just crazy! And you have an SO, too. I don't get it. With my EZ I couldn't get 1300 degrees going 70mph, flatfooted towing 8000 lbs. I wonder if my truck is goofy?
Andy
Old 04-20-2006, 03:38 PM
SOhappy's Avatar
Andy
I've got a video from last Saturday night, pulling my ~10,000lb toyhauler up a ~6% grade. It shows me doing 70mph at ±2800 rpm in 3rd. I'm pulling 30psi and about 1300° (pre-turbo). EZ set on level 2, boost elbow and no other mods to my SO . Needless to say, I'm very pleased (keeping up with normal traffic just fine ). Which is more than I can say for my friend's: Older non-powerstroke furd, newer 6.0l gasser chebby, and 454 gasser Burb. They all reported around 35-40 mph while pulling less weight.
The video is kind of fuzzy (since it's dark) but I'd be glad to post it somewhere/email it if anyone is interested.
My (limited, since I just installed the gauges) experience has been that pedal position doesn't drive egts, but rather rpm.
tinknocker827
13
12-04-2013 06:26 PM
dkimmel
06-03-2010 06:13 PM
lgp9999
09-08-2007 11:19 PM
cheff
01-23-2006 09:44 AM
klrmark
09-04-2003 09:37 PM
Quick Reply: How high is too high?
