How hard is it to install valve springs?
Old 02-18-2008, 08:43 AM
UnrulyNFS's Avatar
I'm getting the wild hair up my tale to try it myself.
Old 02-18-2008, 08:52 AM
RowJ's Avatar
Third gen should be more accessable than my 2nd gen. Wasn't bad with the Cummins tool which lets you do 4 (each cylinder) at one time.
If you have the service manual... just follow directions and go for it!
If you can change injectors you can do springs! No master mechanic skills required.
RJ
Old 02-18-2008, 09:01 AM
UnrulyNFS's Avatar
Anybody have a part # on that tool?
I don't have the service manual. But I have changed injectors before. I actually got some Flux 2's that need to go in at the same time which is why I'm considering it.
Anybody got a copy of that section of the service manual I can borrow?
Old 02-18-2008, 09:55 AM
Jetpilot's Avatar
Cummins spring tool part #3164329
Old 02-18-2008, 10:24 AM
UnrulyNFS's Avatar
Originally Posted by jrussell
Just do a Google search for "Stolen copywrite protected material". Should be one of the first sites that pops up. Look on the bottom left of the website.
I actually found a copy of the manual on my computer just now. What luck!!!
Thanks for that part # Jetpilot.
Old 02-18-2008, 01:51 PM
haloman's Avatar
Wow lots of people are wanting springs with the soon to be release 4k smarty program
Old 02-19-2008, 08:40 PM
UnrulyNFS's Avatar
Bingo
Old 02-19-2008, 08:56 PM
JFlory's Avatar
Springs are pretty easy, just time consuming.
Just a little FYI: The keepers will NOT fall into the cylinder threw the injector hole, and it is a pain if they fall down the push rod hole.
I usually stuff paper towels in the push rod holes and use a good pencil magnet to get the keepers off and safly into a small cup.
Biggest thing is take your time.
Good luck.
J.D.
Old 02-19-2008, 09:04 PM
homewrecker's Avatar
So how do you keep the valves lifted(not drop them in the cylinder).Will the guides hold them in place?
Old 02-19-2008, 09:46 PM
JFlory's Avatar
You have to rotate the engine so that the cylinder you are working on is at TDC. The piston holds the valves up. I use a baring tool to rotate the motor.
I use a small piece of wire down the injector hole see when it's at DTC.
You can do 1-6,2-5,3-4, but I still double check for DTC on all of them.
J.D.
Old 02-19-2008, 09:53 PM
Appreciate it JD.......
Old 02-19-2008, 10:24 PM
nelrod's Avatar
How much are a stronger set of springs and how much to get them installed? I'm not mechanically challenged, just getting older and lazier and luckily have a little more dough than I used too. For now anyway.
Old 02-19-2008, 10:30 PM
I'm gonna try mine soon.Done them on my 2 2001's with the head off.Can't be to hard.I'll quote you a price after I see how big of a pain in the butt it is!Where do you live at.I'm between Statesville and N. Wilkesboro
Old 02-19-2008, 11:06 PM
UnrulyNFS's Avatar
homewrecker,
I'm not too far from you. Wanna go sledpulling with me some this year?
Old 02-19-2008, 11:15 PM
Originally Posted by UnrulyNFS
homewrecker,
Man I've always wanted to try it but the thought of hurting my baby makes me sick.Don't think the con ofe would like it very much.Where do you pull at?Got a couple friends that pull at Big Lick and up here at Tomlin Mills exit.
Quick Reply: How hard is it to install valve springs?
