How far post turbo can the EGT probe be installed?
I have an EGT Autometer gauge I want to install, but don’t really want to drill and tap the cast metal on the manifold or elbow that is just post turbo. I understand the manifold will give the best cylinder readings and post turbo elbow will be about 300 (or so) lower. I’d like to just mount (weld stlye) the probe a few inches past the cast elbow. This location is about 6 inches past the turbo and pretty easy to install w/o tapping. Would anyone recommend this as a location to read EGT’s? Could I just say this location is about 400 degrees less than a manifold reading?
Here’s the reason for the EGT gauge. I have an EZ Edge (600 motor) installed and mostly use settings one and two. I also almost never tow or loaded and drive it pretty easy. I may not even need an EGT gauge, but the EZ Edge could add some higher EGT with my driving style?
Yeah, I would do it right the first time and put the probe pre-turbo. Get the most accurate EGT info, then you won't have to guesstimate on your temps.-Steve
Post Turbo is fine. Follow the pipe after the turbo and keep going. When you walk out past the back of the truck, keep going. When you come back to the front of the truck and see the manifold, put the sensor right there in front of the turbo. I believe between 2 and 3 is the recommended spot.
92smokin blacky
02-23-2011 07:18 PM
