How far out will moto metal 957's stick out?vs stock?
so how far out will the moto metal 957 stick out on my truck. they are -12 offset and 4.5 " backspacing and they are 17"by9" . i was told they would only stick out a 1" more than stock setup. is this correct?
so do i take the 2.5 and add 1.1" because of the offset? i was told the moto metal 957 would only stick out another 1.1" vs my stock dodge tire setup. i have the big bushwacker flares (pocket i think) and would like the tire to be more flush with the fender.
https://www.rsracing.com/tech-wheel.html
maybe this will help...
I personally think you should have a wheel with closer to 5.5" of backspacing if you run a 12.5 wide tire?
thanks. i have that chart. when i go to column 9" and go over to 4.5" BS i get a offset of -12..which i knew already.all i wanna know roughly is if a 17"by9" rim with a offset of -12 and a backspacing of 4.5" work on my 2004.5 stock truck with no lifts/rubbing? will it be flush with the pocket flares or stick past them yet?
lol. sorry. im not sure about tire yet. ill probably go bfgs all terrain 315/70 r 17s or something close. probably no bigger though
my truck isnt here with me thats why i ask and seem like a pita lol sorry
any1? i know the 17"by9" moto metal 951 have same dimensions as well. both the 957 and 951 are 17 by 9 8/165.1 -12 offset 4.5 backspacing....will they work onour trux or will the hit caliper? fender?
Thinking of the stock rim which is 8" wide with 6" backspacing. When mounted on the truck, this means the back of the rim is 6" behind the face of the hub. Therefore, the front of the rim is about 2" outside the face of the hub ( 8 - 6 = 2).
With a 9" rim with 4.5" of BS, the front of the rim is 4.5" outside the hub face ( 9 - 4.5 = 4.5). That's 2.5" further out than stock.
Shelljerk47
06-16-2009 11:56 PM
tands1000
10-28-2005 12:55 AM
