How do i take off Head linner and cubby hole dash
Old 05-04-2008 | 04:53 PM
tatkins85's Avatar
hey guys, i just wanteds to ak if any of you had pictures or good info on what to take off to get the headliner off in my 2006 dodge ram cummins 2500 slt? i can get it off but ill probably take off way more then whats needed and theres probably a simple way on getting it off? and i aslo wanted to get of my front dash arounf the sterio i wanted to get the cubby holes out beacuse i wanted to my a switch mount in one of them? what needs to come off the get that off and do you have any pictures of this aslo. thansk 4 the help guys.
Old 05-05-2008 | 07:05 PM
Nsomniac05's Avatar
to get the dash off, strattle your console. there is a hook by your right knee. remove the screw and give that hook a tug and im sure you can figure it out from there. the whole piece comes off as one. just work your way around to all the snaps, and be carefull not to break any of them.
Old 05-05-2008 | 07:07 PM
tatkins85's Avatar
thanks 4 the help
Old 05-05-2008 | 07:10 PM
Patriot2500's Avatar
Not to hijack, but is that the easiest way to access the cubby hole under the heat/ac controls?
Old 05-05-2008 | 07:19 PM
Nsomniac05's Avatar
not the easiest. the only. just remove the one screw, and the whole center dash piece comes off as one. there is no other way.
Old 05-06-2008 | 06:55 PM
tatkins85's Avatar
i did not see a hook by my right knee? when i sit in the middle seat, the only thing by my right knee is glove department? so i dont see a garbage hook or any type of hook or a screw? any more info?
Old 05-06-2008 | 07:10 PM
Nsomniac05's Avatar
ok well i do have an 04.5, vs your 06, but i dont think the interior has changed any. also i have the SLT package, the only difference i could see is if you had the Laramie with the wood grain, that might be different. but it really is simple. it is horizontally between the radio/climate control and the glove box. vertically it is just below the inner passenger side air vent. when you see the hook, look above it, up under the overhang, and there is the screw. good luck.
Old 05-06-2008 | 07:18 PM
tatkins85's Avatar
i have the slt but mine dos have wood grain on it.
Old 05-06-2008 | 07:28 PM
tatkins85's Avatar
hhhhmmmm. well im stupid or the interior is different. personally i think its both. anyways still dont see a hook or a screw or anything around that area.
MikeyB
13
06-26-2012 09:16 PM
Mechanos
03-12-2006 10:57 PM
Bad Ramer Jamer
12-03-2005 10:27 PM
Truckjerk
08-13-2004 02:14 PM
ATVConnection
03-04-2004 03:58 PM
