How do I...............
............get the box off my truck to install my AD150? Dropping the tank is not an option.
I'll be doing this myself for a few hours after work every night for the next bit until finished. Truck is in the garage - I have a company truck to drive to work so leaving it is no issue. However, I don't have any fancy lifts or anything.
I'd love to, but I'm a one man show on this one. All buddies are currently out of town away at work right now. My Dad is away as well. My neighbors are elderly. My Uncle is puny and my brother's wife doesn't let him out t play during the week - whipped.
So, of all times..........this is what I'm up against. I have three people - me, myself, and I.........not necessarily in that order either.
Ok well then I would rig up a pully system or come along from the rafters and use rope to go from the stake pocket holes to the center of the bed and lift it like that or find a way to just lift the one side enough to get the job done. Tell me what you have to work with and I'll think of something that will work.
I was in the same situation a week ago. I was doing my AD150 install and I didn't want to drop the tank and risk the 1/4 tank issues. I had a hoist available but as a one man show it was just way easier to drop the tank. Time was a factor for me, plus my low fuel light was on. This helped my decision. I've run it to the E with no probs yet.
FWIW a guy at work used a floor jack with a 6x6 block of wood to jack up the bed and then put blocks between the bed and the frame when he had enough room to work. Personally I'd have been a little nervous.
Dave
Dave
I say you would be better off removing the tank. The bed is heavy and bulky. Go burn some fuel and remove the tank. Just make sureit's clost to MT and use a jack pref. a trans jack works pretty well.
If I didn't decide to go in from the top I'd just use the wooden blocks. It's nearly impossible to crush a wooden block. I put a 300 ton crane up on wooden pads the other day on concrete and they didn't leave a mark. Just loosen the bed bolt and jack up one side if you're set on not dropping the tank.
I thought about lifting from the rafters as well, but a little leary on leaving it that way for three or four days. I've also thought about the engine hoist idea, but I do have to get around the front of truck to my tools. Trust me, every viable idea I've thought of has come around to bite me about something that thwarts it.
I even thought of loosening the passenger side bolts only and lift the driver's side up, but something is going to bend for sure.
I just need a longer garage - then lift and roll truck forward.
I dont know what kind of time frame you have, but I will be home next week and I would be glad to give you a hand to lift it off, I'll even round up a few buddy's.
Thanks. I will keep this in mind come closer to the weekend. In the meantime, I'll see what I can come up with.
AD= "AIR DOG", 150= the 150 gal./hr model. It is an aftermarket fuel system.
The reason I have to remove the bed for my install as opposed to dropping the tank, is I have some funky ideas about my install that requires the tank to stay in the same configuration as is until I get my ideas sorted out as to what will work and what won't.
I had about 4 or 5 people help me lift my bed off. its just easier I think after you get the bed off instead of trying to mess with the wiring and the drawstraw to just remove the bed. if you can get access to a crane and have some sawhorses setting around it would be helpful. there are a couple torx headed screws around the gas door, one ground strap running to the cab from the bed and 6 bed bolts. 53 ****** put a really nice write up on here on how to do this. you have to remove the tailights and take the wiring out for them also to get the bed off. its really not that bad at all just take your time and do it right. look for the write up on here it will help you alot
