How To Control Boost W/ Smarty Aftermarket Turbo Program?
if i load the aftermarket turbo program and run it w/ my stock turbo how would i control boost pressure? the website says it disables the wastegate and the boost wont be controled.
DTR 1st Sergeant
First, you are not modded up with a bunch of fuel anyway so I don't see you driving the turbo too high in any case. With that program and Smarty alone you might see about 40-42 psi. That is at the upper end of efficiency range but you will be ok. Just watch egts. Boost is going to be controlled by the total amount of fuel you give it. The aftermaket turbo program does the boost fooling so you won't throw a high boost code.
thanks for the info. what about the tq management levels? what is the difference between mild, moderate, and wild? and which one would be best to use driving conservatively w/ my stock 48re until i upgrade my trans?
bigwheels94
04-11-2008 02:27 PM
TexSoftail
02-05-2008 08:09 PM
bluebull
01-01-2008 10:50 AM
Shank
08-27-2007 10:58 PM
bluebull
08-16-2007 04:51 PM
