How can I get more boost?
Old 09-02-2008, 01:36 PM
rmalone's Avatar
Given your fuel your seeing what you should. Keep in mind that the intercooler and cam are reducing boost, your getting the air into/out of the engine more efficiently (cam) and your IC is cooling the air better thus reducing pressure. Boost is not the "be all end all".
Where is your egt at 40psi, if you feed it enough fuel to make 50psi your still gonna see much higher egt. My sps66 wouldn't make 50psi without enough fuel to see 1400-1500egt. With the twins and TST on 1/1, flux 1's also it will make 48-50psi at about 1050egt. Mind you I am on stock intercooler and cam. Shoot for the power you want at egt you can live with and don't worry too much about total boost.
Old 09-02-2008, 01:50 PM
cquestad's Avatar
I see more with the MP-8? It boost fools on the top...hooke dinfront of my TST...but I still bury the TST boost gauge at 40-41 (max OEM sensor).
I really have no idea how that happens since the MP-8 should cut it below 30 I imagine...
I just don't worry about it.
Totallyrad
07-19-2011 07:41 AM
Bowser50
06-15-2009 12:38 PM
kyle_truck_pull
10-29-2008 02:35 PM
Quick Reply: How can I get more boost?
