How big is a Garrett GT45 Turbo?
I have found what might be a good deal on this turbo, but I am trying to figure out how big this unit is, say in reference to a silver bullet or a aurora 5000
Thanks
Kevin
Thanks
Kevin
GT45 has an 81mm compressor wheel@ inducer and almost a 90mm turbine wheel.
Its a step up from an Aurora 5000.
It would be good for a bottom turbo in a multi setup.
Not so good though for a single turbo setup? If a person could get this for under 500 bucks it would be a good deal?
Do you think that it would work good in conjunction with my silver 62 in a compound setup?
Kevin
Kevin
I have a GT45R...dual BB...It has a 81.6mm wheel, and an 87mm turbine wheel in a 1.01A/R housing. It should spool better than a B2 and move more air...but I'm also going to run an external wastegate on it as well.
It should do good with your 62 too...but I wouldn't go with the tight turbine housings unless you want to wastegate it...stick with the 1.24 ( I think that's the biggest one!)
Chris
LOL,, thats what I am trying to do!! All this talk of big power,, I want to go fast, going to race this season, pretty much status quo, but next winter,, roll cage, and craziness
Kevin
Kevin
Garrett doesn't have a flat place for a tag in the compressor cover they cast their name and that's 1 of their copyrights,and also a gt45 compressor wheel has the nut cast into the wheel and not a separate nut,and that's called a boreless wheel .
GT45's are all ball bearing and the biggest one will be an 80mm. They are physically really close in size to a GT42 and much smaller than a GT47
HOHN
60
04-02-2008 09:47 PM
stillsmokin
12-10-2007 02:33 AM
Caterpillartim
11-10-2006 06:28 PM
GlennRMK
05-09-2006 09:07 PM
