Hot" Juice Stacked with - EZ
Well I finally Installed the Edge -EZ To stack with the Hot Juice I already had installed,
Results
Definately Nice Pull off the Line Fill Now, And Some Noticable Smoke output, clears up quick Nothing like my
2-nd Gen with the Edge Drag Comp and mach-4 150-HP sticks, I felt Like Bat Man laying out the Smoke Screen on that Truck.
A definate Nice addtion to the Hot" Juice with Attitude.
I am only using levels One or Two on the EZ as I here this is High as you want to go on the EZ Fueling Side. So Far Stock CP3 , Stock Injectors, undecided Next move would probably be a Dual CP3 set-up dual stock pumps, And then some 70-90 Max HP injectors. I have a Joe Hellmann Intercooler on the Way to help keep down some of this addtional heat ,
Results
How far do you plan to take the truck? If all you plan to add are some small injectors, you aren't even close to needing dual pumps. You can get a modded pump for a whole lot less money from Floor It or Darksidedieselworx.
PEAKSTRYDE
10-11-2007 04:20 PM
zcb6915
23
09-24-2007 10:56 AM
Ramtuff06
07-07-2007 11:04 AM
reidsram
02-10-2007 05:06 PM
