Homemade Walbro Kit install + Aux Fuel Filter Write up
Old 07-02-2007 | 09:00 AM
  #31
dezeldog's Avatar
That my friend is by far the most detailed write up that I have ever read. I put the glacier system on and had no problems with it as I am kinda mechly inclined but with that write I think a 1st grader could do it. Like I said before, "the best I have ever seen". Thank you.
Jim
Old 07-09-2007 | 07:17 PM
  #32
jthorpe's Avatar
DTR Founder
That is a great writeup. Awesome. Thanks to your writeup and Iker for moving it over, it now sits permanently on the Wiki at:
http://wiki.dieseltruckresource.com/...l_Filter_Setup
Good job!
Old 07-09-2007 | 09:19 PM
  #33
8mpg's Avatar
Good job!
COOL!!!!!!
Old 08-20-2007 | 02:07 PM
  #34
josterbauer's Avatar
I like your write up on this, one question that I had about the check valve. Do you think that the 1/4" check valve will restrict the flow back to the tank too much? Do you think that the 1/2" would be better on your system?
Old 08-20-2007 | 03:08 PM
  #35
Rob C's Avatar
Good job!
I keep getting asked for a user/pass, where do we get one?
Old 08-20-2007 | 03:20 PM
  #36
53 willys's Avatar
it's been down for the last few weeks...Jack is tweaking some stuff..
Old 08-20-2007 | 04:43 PM
  #37
Pooter's Avatar
The fuel doesnt actually flow thru it, so its not really a restriction, it bleeds off excess pressure, so it doesnt need to be the same size as the feed side going to the filter/cp3, its kind of like a purge/blow off to vent the extra pressure.(Vs a dead end style that is regulated inline)
Old 08-22-2007 | 05:07 PM
  #38
HOBrian's Avatar
8MPG- thank you for the write up, always looking for a way to save so money
Old 11-06-2007 | 01:53 AM
  #39
Dr. Evil's Avatar
Its been said before, but I have to say it again - FANTASTIC job on this.
Old 11-06-2007 | 07:24 AM
  #40
rufushusky's Avatar
Originally Posted by coolslice
That's the best write-up I have ever seen on any diesel forum! I do have to admit- even though I understand what I'm looking at and I helped put my FP gauge in, I don't think I could pull something like that off. Very clean. If I lived close to you, I'd pay good money to have you do that to my truck too!
Amen...wow....that is impressive
Old 11-06-2007 | 07:48 AM
  #41
bnold's Avatar
Looks good didn't go through all of it, but great pics... Push lock fittings would have made the install a bit cleaner looking, but I'm OCD about that stuff
Old 11-06-2007 | 09:09 AM
  #42
vzdude's Avatar
DTR's 'Go to Guy'
How did you get into the site? tried my username and password from DTR - no worky!
Old 11-06-2007 | 09:13 AM
  #43
vzdude's Avatar
DTR's 'Go to Guy'
Duh! Went back to the 1st post in the thread and read it! Nice install and documented well!
Old 11-06-2007 | 10:28 AM
  #44
Blast Chamber's Avatar
8mpg, I just saw this write-up, good job! Very detailed.
I did my own Walbro & filter setup in early 2006 before the kits came out, and I had a couple of thoughts about your install to share.
About the location of the filters, I didn't want mine hanging down and exposed to possible damage from road debris, so I fabbed up a custom steel mounting bracket/guard to protect my Walbro and PermaCool filter.
Also, when researching my Autometer electric gauge I found posts that said not to install the electric sender on the engine as it could be damaged by vibrations and pulses from the CP3. I used a tapped banjo bolt from the bottom of the fuel filter canister, added an Omega snubber (to protect from pulses), ran an 18" fuel pressure hose (to protect from vibrations), then installed the sender in a street-L tee mounted in a custom bracket attached to the brake master cylinder. This tee allows me to bleed air out of the line. The sender has held up fine for the past 20 months using this arrangement.
Just my 2-cents. Again, GREAT JOB!
Attached Thumbnails Homemade Walbro Kit install + Aux Fuel Filter Write up-dscf0061.jpg   Homemade Walbro Kit install + Aux Fuel Filter Write up-fuelsender.jpg
Old 11-06-2007 | 12:33 PM
  #45
bnold's Avatar
Just noticed this was for sale in the classifieds?? Wonder why he is selling?
Quick Reply: Homemade Walbro Kit install + Aux Fuel Filter Write up
