home made big line kit
can i get pics showing which hoses from stock filter housing and cp3 go to the big line kits. as i was gonna build my own that way later i can add 2 mic filter between when i get lift pump since i am afraid stock lift pump might not push through 2 mic filter
Look at Glacier diesel performance's website under their install guides. Basically its the line that goes from the bottom of the fuel filter housing to the CP3...cant miss it.
You need 1/2" diesel rated pushlok hose, 12mm to -8 (2 of them), and 2 90* -8 elbows... If you add a fuel filter base, you need 2 more 90* elbows, and 2 -8 to -12o-ring boss connections for the fuel filter housing.
Flatbed24v
07-31-2009 10:57 AM
