High performance trans time. ATS or Suncoast?
Old 11-15-2011, 12:55 PM
AndyD's Avatar
i have had trans work done there before but i forgot about them. it was on my 91 f250 i believe they charged me 2300 for a full rebuild and i had no issues with it
Old 11-15-2011, 03:10 PM
Tray's Avatar
I have a Goerend but if I had it to do over again I would probably try out DTT.
I'm pushing $8k in my Goerend only to have it die on me a couple of days ago with 48,000 miles on it. I've always babied my transmission and my truck does not push big power at all (I run a smarty on 3 usually). While Goerend will cover the tranny, I'm out the $$ for shipping (both ways) and install of the replacement. With that kind of money invested, then this money going back in after only 48k, I'd have been better off to go with a stock tranny.
Old 11-15-2011, 05:00 PM
Lost Lake's Avatar
Tray,
Would you do the BD Shift Enhancer again?
Old 11-16-2011, 11:15 AM
Tray's Avatar
Originally Posted by Lost Lake
Tray,
I probably would. I don't really get any use out of it as I tend to forget it's there. I have had a problem with a big footed mechanic jerking the power wire out of it and causing a check engine light and the truck to shift funny, but it does eliminate the 1-2-1 shift that used to pretty much drive me insane.
Old 11-16-2011, 10:41 PM
texastuff's Avatar
Originally Posted by AndyD
haha check this out i called Trans Ex in Stephenville and he said 4100 for a fully built that will handle up to 900 horses i asked him how legit he was and he said that valair uses his torque converters in their race trucks haha wow in small *** stephenville
b.s. Valair has their own torque convertors, but they did have a tranny built there Dan told me trans ex did build his tranny
Old 11-17-2011, 09:59 AM
Lost Lake's Avatar
Why would you have a 1-2-1 shift problem with a brand new Goerend transmission?
That's my problem with the Shift Enhancer. I think it is designed for stock transmissions. Even Craig said they just leave it on one setting and forget it. Well if you just leave it, why not set the trans up at that pressure and be done with it?
I'm leaning towards NOT putting it on.
Old 11-17-2011, 05:54 PM
no_6_oh_no's Avatar
The shift enhancer just implements a different pressure ramp that is more aggressive early to eliminate the shuttle shift. You can simulate a lot of that by bumping the TTVA motor 1 tooth. If you teach yourself to drive with a heavier foot initially then back off as the trans upshifts the shuttle is a non problem.
The other is just chase it and try things until it eliminates or mitigates it.
Old 11-17-2011, 09:49 PM
J.Suplanski's Avatar
Thumbs up Trans
MY CHOICE WAS SUNCOAST
Old 12-02-2011, 01:48 AM
AndyD's Avatar
well i went with this local shop, he put red devil clutch packs hd bands and servos, billet input and intermediate shafts and a triple disc torque converter with a yr warranty for $4000
Old 12-02-2011, 02:22 PM
COUNTRYBOY's Avatar
Well???? how do you like it...???
Old 12-04-2011, 01:27 AM
AndyD's Avatar
drives great night and day difference just cant wait to get my silver 66 on and see how it all flows together
Old 12-13-2011, 04:26 PM
dodge2005's Avatar
I have ATS stage 2 transmission. Yes the transmission did shift hard, new. I have roughly 3k on the transmission with about 600 of those miles towing my 5th wheel from Denver to Steamboat springs and back. After towing, the transmission shifts a lot nicer. I did upgrade the flex plate, and input shaft to billet. So, for the moment I am a ATS fan.
Old 12-16-2011, 04:25 PM
rexsti's Avatar
goerend
Old 12-16-2011, 06:45 PM
Bankdude's Avatar
Can't say anything bad about the other guys, but I love my Goerend.
It's been a solid performer and a great platform to build on.
Spooler
33
10-15-2008 04:47 PM
weldman05
06-15-2007 03:12 PM
blackdodge24
02-23-2007 12:39 AM
ckennedy
22
06-24-2006 04:04 PM
Quick Reply: High performance trans time. ATS or Suncoast?
