High performance injectors
With the performance I am getting with the TST, what good would installing higher HP injectors??
My truck at www.GoRowan.com/2004ram
Lower your EGT's, at least that is what I was told. It was definatly worth the swap, truck was much more responsive with just the Edge EZ and new injectors. Then I added the BullyDog Power Pup to the mix, all I can say is "Hang ON!". Ever feel the front end of your Dodge lift OFF the ground, rear end squat, and loose your steering on dry pavement? You should have seen the look on my wife's face! It was priceless!
Just wish I would have went with the 140hp ones.
Mike
Mike
Performance & Accessories ’89-’93 Dodge CTD High Performance DDP Stage 3 Injectors – 1 Set of 6 Used @ $400
InjuredOften
1st Gen All Products
04-28-2015 02:33 PM
cumalong
05-04-2009 09:50 AM
TxDiesel007
06-29-2005 10:31 AM
BamBam
20
12-24-2003 08:50 AM
