high egts! water meth or new intercooler?
Don't know 3rd gen but I only dropped 50* with aftermarket intercooler.
Bigger turbo is best bet. H2O/Meth with a progressive controller will drop temps 200* for all but WOT.... great for towing. And temps climb much slower if WOT.
Just keep the meth down to 20% or less if egt's are main concern.
RJ
RJ
DTR 1st Sergeant
I go through way too much water to add any meth... 1000+ lph = about 150* drop for me. The CAC was worth about 75-100*.
I would go in order: CAM, CAC, then water. Address your breathing first, then add water. Reason? The cam and CAC are working all the time... you can run out of water, and will.
hey soulzoo, i guess your sled pulling, or towing heavy, going thru a ton of water.i just use it for racing at the track, ill get 5 runs, and still go home with over half full.
madhat's monkey boy...
DTR 1st Sergeant
While towing, I will go through a tankful after about 75-100 miles if I set it low enough.
For just cruising empty and no pedal mashing, one tank will last from 450-600 miles, or about the same as a tank of fuel.
thats over a full gallon for 1 pass down the track, that doesnt sound right at all to me, but if it works for you its all good. now that i think of it, if i hold a gallon of water upsidedown it takes a little over 10seconds, so do tell.
yeh i have the stage 2, works pretty good for me. gave me almost 2 tenth's in the quarter, and 35 ponies on the dyno.i just never heard of such a thing, i cant believe its not quenching your motor.
turbo and cam before i/c...Mike Lazar (XLR8R aka Lazarsmith) tested some aftermarket i/c's and was telling me they didn't flow better with any of his fancy tools the diff was almost unmeasurable...
I agree try this first. If your going to add water it takes more than a simply kit to get any real benefit. I am running 5-625 nozzles a 220psi pump and a 150psi pump. Snow stage 3 comes on at approx 10psi boost on boost setting for the 220 pump and first 3 nozzles and hobbs switch makes next 2 nozzles come on after 35 psi. I do go through alot of water though. I only use were water is allowed if not I just live with the high egts for a short period even with all the above items with same turbo.
An intercooler is going to give you more and doesnt require a tank to be filled up. It is the upgrade that just keeps on giving. Our intercooler definately flows way better than stock, has a much higher efficiency ratio and a much larger surface area. The intercooler is definately going to be a better route for every day driving.
