high beams and fog lights
Old 11-06-2006, 12:27 PM
Boykid88's Avatar
Stick a diode inline with that jumper and it should fix up any backfeed issues from other circuits.
Old 11-06-2006, 01:00 PM
ptgarcia's Avatar
My fogs work with the high beams without having to add any jumpers, diodes, relays, or anything else. I bought the factory fog light kit with factory replacement switch and installed them per the instructions and ended up with fogs that stay on with the brights.
Old 11-06-2006, 08:29 PM
1 bear's Avatar
Question Silverstar
I was told that those bulbs will melt the wiring harnesses. They get to hot.
Old 11-06-2006, 08:53 PM
Boykid88's Avatar
I've had them in mine for over a year now with no issues but I did burn the switch out of my 95. If you catch the switch in time then the heat doesn't travel up the harness as bad.
Old 11-17-2006, 09:15 PM
Allnew2me's Avatar
I have a 2001 also and here is how I did it with mine, not sure if other years is the same. The foglight relay exists only to turn off the fogs when the highs come on. If you remove the relay you can place a jumper, I used 12 gauge copper, between the two sockets closest to the fender. they are the two that run in the direction of the truck. This allows the lights not to stay on, but rather, not to be turned off when the highs are on. Works great and is free.
Old 11-19-2006, 02:52 AM
Fisherguy's Avatar
Those 'jumper' mods will NOT work on an 06, completely different, no relays etc.
Been discussed many times here, do a search.
Old 11-19-2006, 08:37 AM
EQUIPPRO's Avatar
Go to the dealership. They can do it diagnostically. They enabled my high idle feature and high beams with fog lights on. The tech has to look for the export option in the "headlamps" "window" to be able to add the feature so your high beams will stay on. It took him about 4 mins. No jumper wires....
Old 11-19-2006, 11:48 AM
Fisherguy's Avatar
Really?
Can they do, hi, low, and fogs all on at once?
Old 11-19-2006, 02:12 PM
samgovol's Avatar
06
my mega cab 06 allows me to use my foglights while running my high beams.
Old 12-08-2006, 05:02 PM
jsafe's Avatar
I just talked to the dealer and he said "Its against the law to have your fog lites and high beams on at the same time" now what should I do sense he wont do it ????
Old 12-08-2006, 08:58 PM
gus's 03's Avatar
ask to talk to a tech or a service wrighter that knows his Edit from a hole in the ground...
i hate talking to the " know it alls" at the dealorships...
hell one of the tryed telling me that putting in a high flow air filter would void the warrenty ... " it leans out the air fuel ratio causing the motor to run hotter and it'll eventualy cause damage to the catalitic converter and other parts of the emisons system , as well as posably burn the valves..." i started laughing so loud the owner of the dealorship came over to see whats up.. aperently it wasnt the first time that had hapened and he got handed a box to clean his desk out and asked to leave....
Old 12-08-2006, 09:22 PM
Luvnacumns's Avatar
On my 06 mega they stay on all the time high, low or no lights.... You can also enable with theBDTD....
Shane
Old 12-09-2006, 08:41 AM
scoggins's Avatar
Wasn't there a post or thread that gave alist of things to request when you go to have a reflash done??
Where did it get put?
Old 04-21-2007, 07:14 PM
Desert Dually's Avatar
good question! Status?
nfc90
10-28-2019 04:24 AM
Tyeopalinski666
01-16-2014 03:59 PM
handymantim
16
07-30-2012 12:34 PM
vtec_vigor
21
06-06-2010 12:37 AM
mamm7215
19
06-04-2004 09:39 AM
Quick Reply: high beams and fog lights
