Hey Marco, Can Smarty Be Programed To Stop Heater Grid Cycles?
Old 02-18-2008, 07:13 PM
  #61
carl48's Avatar
i removed the heaters from three of our 2006's on the first one i removed everything including the relay it set off the check engine light and code 541 as shown on smarty jr i measured the anp draw of the relay it was 0.8amp i found a 20 ohm 10 watt resistor and hooked it up to the two controll wires reset the codes with the smarty and no problems the next one i tried a 25 ohm and it set the code off i scrounged around and found a 16 ohm and a 15 ohm i installed them and no codes after that on any of them , the ecm must see near 0.8 amp draw to the small black wire with the yellow tracer when it calls for grid heat the best i can figure
Old 02-18-2008, 08:04 PM
  #62
levigarrett76's Avatar
how did you disconnect the power(from where)???
all i have left hooked up is the relay with the two control wires and the power lead to the battery....everything else is gone
sounds like the guy above has it all figured out!!!
Old 02-18-2008, 08:23 PM
  #63
Ghost Ram's Avatar
the two small controll wires you are speaking of are a trigger wire and a ground for the relay. the ecm detects voltage drop from somewhere else.
Old 02-18-2008, 08:49 PM
  #64
jmccart's Avatar
OK, I did this today. I installed a GDP airhorn & a Winspeed grid delete. I disconnected the thick black cable from the grid heater and also disconnected it from the battery. I did not notice any other wires. I started it to take it for a quick cruise this evening (52* F). No CEL light. Where are these other wires?
Thanx.
Ramrod90
02-03-2009 07:39 AM
prairie pirate
Introductions / New People
01-18-2009 10:26 AM
rstone
04-05-2007 10:42 PM
taildragger
12-04-2006 10:00 AM
deezul
10-07-2005 02:41 PM
Quick Reply: Hey Marco, Can Smarty Be Programed To Stop Heater Grid Cycles?
