Help wiring Dipricol EGT
I need help. Where do all these wires go. If anyone has recently done an install on a Dipricol EGT I need some pointers. The light bulb has two black wires. The harness has a black and white wire, in addition to the thermocouple. Please help.
John
John
Well it's pretty straightforward. The two black wires from the bulb: one goes to hot and the other to ground. As for the led light (which are the other two wires in the block in addition to the thermocouple wires) I don't remember off hand which is which, but they are clearly marked. One goes to hot and the other to ground. if you test it on a 12V battery first you will know which way they go as the led light will only function if wired correctly. Hope this helps
Mishkaya
Mishkaya
cLAYH
06-22-2015 08:55 PM
TNLoneWolf
04-05-2008 10:46 AM
HP Upgrades
04-20-2006 10:20 AM
bauer500
09-06-2004 02:41 PM
