Help with wheels again....sorry
OK. I'm still lost on what's going to fit and what's not.
Need a set of 17"x?. Prolly 9" wide.
Most of the wheels I'm looking at have a 4.5" backspacing, but then the offsets vary from-6mm to -12mm or more.
I understand the 17"x8" factory alloys to have a 42.3mm offset (1.7"). So I'm figuring the stock wheels to have a 5.7" backspacing.
So far so good?
HOWEVER...none of that tells me what the limits are without rubbing.
A 9" wheel, with 4.5" backspacing & -12mm offset I think is...almost 5"?
Is that going to clear and just stick out?
So far so good?
17x9 pro comp 1079 on 315 nitto dune grappler. 4.5" BS No problems with rubbing w/ a leveling kit. These are older pics. I was running a 315 hankook MT back then and did not have stacks.
Approx how far do those wheels stick out past the fender, although great pics it's hard to tell, maybe you could pull some rough measurements. Thanks
that sounds about right. I like some wheel outside the fender but not too much. Your paint however, will suffer if you travel on gravel much w/o some mud flaps or fender flares.
So far so good?
So far so good?
Steven K
06-04-2009 10:32 AM
dealseeker
43
11-18-2002 11:47 PM
