Help...trying to updare Smary
Im on the search for best driver page and im on C: now what?
directions say to enter D2XX Drivers, that doesnt work and i search for drivers in c: and get cannot install this hardware
O i need to install one of these. All it says on the Smarty USB Driver install guide is to disconnect from the internet, plug the smarty in, click no on the new found hardware, click install from a specific location, and search for the best driver
Smarty USB.exe
Smarty USB downloader ver. 3.03A
optimized for Windows XP®
Oct, 7, 2006
529 KB
SmartyUSB.zip
Oct, 7, 2006
278 KB
SmartyUSBL.exe
Smarty USB downloader ver. 3.03L
Oct, 7, 2006
528 KB
SmartyUSBL.zip
Oct, 7, 2006
277 KB
FT232_D2XX_Driver.zip
Smarty USB driver *
(not recommended)
Dec. 12, 2005
280 KB
CDM_2.00.00.zip
Smarty USB driver for Windows 2000
and Windows XP *
Oct. 21, 2006
379 KB
D30104.zip
Smarty USB driver for Winsows 98SE
and Windows ME *
Oct. 21, 2006
273 KB
Smarty USB.exe
Oct, 7, 2006
529 KB
SmartyUSB.zip
Oct, 7, 2006
278 KB
SmartyUSBL.exe
Oct, 7, 2006
528 KB
SmartyUSBL.zip
Oct, 7, 2006
277 KB
Smarty USB driver *
(not recommended)
Dec. 12, 2005
280 KB
CDM_2.00.00.zip
and Windows XP *
Oct. 21, 2006
379 KB
D30104.zip
and Windows ME *
Oct. 21, 2006
273 KB
I am having a problem updating mine it said it is unable to connect to smarty or smarty not found. When I go to control panel add new hardware it seem that I can not found the usb for the smarty. NEED help please I am not that good with computer.
got the mads website madselecronics.com. In the downloads section there are multiple files, you need
1. a driver file for windows xp or 2000..dont use the one that says not recommended.
put that in a folder you will remember when it asks you where to sae it to
then double click on it and when it opens click on extract that will pull the files down to a folder again that you name. when you plug the smarty in and it looks for software to intall the device you point it at the second folder u just created. That should do it when it says hardware successfully installed.
then you have to go get the usb upadte pgm this is the thing that you run to get a file put onto smarty, you also need the smarty softare itself. one you down load that then you can have the updater put that on the smarty.
Did you download the USB driver to a local folder? If so run the new hardware detect and do not select the recommended in the wizard, bypass that and go to manual install and using the browse find the .dll file that you downloaded and unzipped in the folder you created.
MikeyB
MikeyB
FYI: IF any of yall have had Bullydog updating programs on your computer, delete all of those files and items associated with it. The smarty uses some of the same drivers to update.
(Ramwheelsby taught me this, maybe he can chime in here for more help)
BEFORE YOU HIT THE SEND BUTTON ,YOU NEED TO LOAD THE SOFTWARE INTO THE SMARTY USB.EXE.
OPEN SMARTY USB
GO TO FILE, OPEN, LOOK IN ANND THEN DOUBLE CLICK ON THE SMARTY SOFTWARE.
IF THE FILE IS LOADED CORRECTLY , YOU WILL SEE THE FILE NAME ABOVE THE SEND BUTTON
I HOPE THIS HELPS
OPEN SMARTY USB
I HOPE THIS HELPS
Bob I must being doing something wrong I going to the smarty usb and I open that up and the screen comes and said send and then I go open the smarty program then it back to the send screen and then i hit send and still said smarty file not found
Are you double clicking on the file you want? If you single click on the file does the file name appear in the file name box? What driver are you running?
