Help!!!!! Truck Keeps Dying
Everytime I Start My Truck And Take Off, Eveyhing Seems Fine Until I Slow Down Or Stop. Then It Dies. I Put It In Neutral Restart It And Its Fine. I Cant Figure Out Whats Wrong?
06 Mega Cab, Ats Compounds 3000 & 5000,ats Dual Cp3's,stage 4 200h Inj,arc Flow Intake,head Studs,ats Full Billet Tranny,ats 5star Converter,copilot Lockup,afe Stage 2,fire Rings And Big Valves,fass Lift Pump,mbrp Dual Exhaust,tranny Cooler,snow Water Meth,smarty Tnt/r,i Cant Remember What Else?
683 Hp 1374 Tq Before Head Work, Also Ordered Tst Power Max Cr
13.36 @ 105.27 1/4 Mile Dyno @ Ats In Denver.
Fuel pressure??? When was the last time you changed your filters???
Also check to make sure that your pump fuse/relay is not bad or loose. Had the same issue and found FP relay was loose....
CLeger67
07-20-2008 07:04 PM
smoky05
01-09-2008 08:40 PM
