HELP !!! Rear Drive line question.
I need Help. Does any one know what the drive shaft angles should be on a 3500 quad cab with an 8 foot bed. I have a two piece drive shaft and am looking for the factory drive shaft angles on the shaft coming from the trans and then the angle from after the carrier bearing I put a 8” lift in & need to shim the carrier bearing. Thank you
Copenhagenjunkie
12-27-2002 05:45 PM
