Help Quick! (another gauge question)
Im in the middle of my gauge install and need to mount and get power to the Pyro box. It says to tap into the ignition wire. Which wire is this on my 06?
The wire for the cigar lighter is a pink with a yellow stripe. By chance I found it on my 06. Look at above where your left foot rests. The bundle of wires closest to the floor, must be 15 or more that plug into that rectangle plug (my plug is white and the one higher is black). Inside that I bundle found it and tested it. Stuck a needle in the wire and tested with the key. I used a volt meter and with the key off was 11v / on was 12v. The instruments work great.
jcmoyer2004
10-29-2009 03:54 PM
cawt0123
08-09-2009 07:19 PM
Jezzhuntin
08-25-2006 02:51 PM
HorseHauler
13
03-12-2006 11:48 AM
