Help, my truck rides like a rock with clay wheels
Hello. I have 2'' spacers up front and nothing else yet. When I had it done, they replaced the shocks. I told them to just put some new shocks in. Now, my tires are all 4 at 65 psi. Give me advice for a Caddy-like ride please. I know the ultimate would be some full on suspension kit. But I just wand to fix this quickly & cheaply so I can focus on speed parts.
Thanx.
Thanx.
you have a 3500 truck made to haul over 10000 lbs its not going to ride like a Caddy. People wanting softer rides and smoother shifting out of these trucks is one of the reasons we spend so much money moding them after DC gets done making them like caddy's.
True. But it now rides much worse than when I first got it. I will drop the tire pressure a tad. I would like some good shock ideas.
Thanx.
I bet its your shocks. What brand did they put in? my truck wasnt to bad when it was new but when i put my 2" lift on I put BDS shocks in and it rode like a brick. then I put the 4.5" lift on and it still road like it had no suspension so I replaced the shocks with billstines. Rides better then when it was brand new. Also I think running that tire pressure with no load is going to cause very poor tire wear and a hard ride.
I don't know what they put in there. I better find out. What did your shocks cost and do you know a model number or something?
Thanx.
what tire wheel combo are you running? If I remeber arent you runnin 305 65 bfgs on stock rims? If so the wobble came from the wider tire on the stock rim more than likely if you do not want to go any taller tire put the 285s on they are the same heighth but narrower hence no mushy wall or tire roll
also I am runnin 33-35psi in my 315s helped out some but will be ordering bilsteins soon
Thanx.
If your thinking about changing to Bilsteins, check out http://www.shockwarehouse.com
Thats where I got mine from and they ran 250 with free shipping.
whitepowertruck
09-06-2013 06:39 PM
LOGAN
Competition / Pulls / OffRoad
15
05-27-2007 07:38 AM
megafast
04-06-2007 08:37 AM
