HELP with MP-8 !!
HELP with MP-8 !!
Hey guys i put my mp-8 on yesterday it was reall easy to put on...but when i went to test drive it it did not feel any diferent...then last night took it down to track and parked my truck, then went to go start it to go get tech inspection done and it started fine but the idle kept dropping makeing it chugged so turned the mp-8 off and it ran fine turned it back on have its some gas let rpm come back down and started to chug and drop in rpm... Oh it was on all the way to track so like 20 miles.No problem with idleing... Anybody have this problem? Did i get a bad mp-8? please help..
thanks Aaron
everything i have is in my sig
thanks Aaron
i would tell mp-8 to replace it. maybe you got a rebuilt one. if you look on ebay you can find just about any chip rebuilt and people trying to sell them dirt cheap. thats why i would never buy a chip off ebay
i actually bought it from alligator diesel performance...i am going to call them on monday to see what up? but i am open to suggestions? also could u guys tell difference with mp-8....
first off, make sure you got the correct model for your truck year, they are real picky about which one works on what trucks...... Make sure you didn't plug anything in backwards........ make sure all connections are tight......... try it again.......... if it still acts funny, take the mp8 off completely and see if the truck runs right with it off...... if it runs right, leave the mp8 off till ya talk to your salesman. relax and don't go nuts over it.
yeah somethings not right for sure, I have mine a quarter turn, don't wanna be to hard on my injectors and with the Smarty stacked with it, runs like a scalded dog...
You should be able to noticeably feel it going down the road at a set speed if you turn it up and down. Cant miss its feel, on my truck when i turn it up you can hear the turbo spool quicker and you can tell you no longer need as much throttle to go any desired speed.
I suspect you may have gotten a wrong one. If it were hooked up wrong it would idle roughly. I would get the part number and model number and call TS performance. Is Alligator Diesel an authorized seller of MP-8???
2500TurboDodge
07-31-2006 04:21 PM
