help me "rig" up 4" exhaust on my early 04.
i have found a few exhaust parts and now need some help putting then together in the right order. here is what i have. 4"elbow, 4" downpipe, megacab resonater, flo pro muffler, stock tail pipe with 5"tip. ill need about 6' of 4" pipe fill in what i dont have.
where to mount the resonator? a foot after the down pipe like a cat or back by the muff (in front or behind?)?
anyone ever turned a muffler around backwards? im planning on running a striaght pipe and cut it so i can clamp the muffler in if i need to go on a long trip. so i think ill try it both way to see how it sounds.
i want the straight pipe sound but trying to stay away from the drone if possible. thanks for any advice
You probably wont need both. The flow-pro should cut the drone down. With the resonator and the muffler its probably going to be pretty quite. Going from totally straight piped to just the straight thru 4" summit muffler on my truck made a big difference for a pretty small muffler!!!
Jason
Jason
Dodgezilla
33
05-28-2010 03:48 PM
MRFD715
05-16-2009 10:52 AM
FATCAT
48
07-25-2008 03:21 PM
CACalomino
20
06-26-2007 08:19 PM
Common
03-11-2007 10:50 PM
