Help me get to 500hp the right way.
#61
Don't feel wrong jilbert, I was told by others the ofe would be sufficient,and that ppl have seen 600+hp on them for years. I'm just worried about its durability. The FE is there for a reason. I don't plan on popping the clutch or anything, not ultra severe use, will tow and play around, i just need it to hold everything I throw at it.
Some opinions on some with ofe and fe clutches? I know the fe is grabby, but is it better to have for my application?
#63
madhat's monkey boy...
I have had 2 bad experiences with con fe's. On the first time, a piece of ferramic lining flaked off and made a hot spot on the flywheel. It did it at less than 400 mi. on the clutch. Got a new one (no questions asked, by the way) and ended up welding that one to the flywheel in about 4k miles (that was my fault ) Anyway, I have had a full ceramic single for over 1 year now and it works good for a lot of stuff. You cant do boosted launches at all without it slipping it the gear you launch in.
Here is a pic of my flywheel from the lining flaking. Supposedly the lining is a material that is pressed at over 100 tons and could flake easily. I was careful installing it, so I know I didnt drop it. It was in the middle anyway. Go double disk and ceramic, then there will be no doubt at all.
#64
What prices are we looking at for a DD ceramic? I have no problem going with either, I just want it to fit my driving habits. I don't wanna be miserable driving the truck I'm about to drop a whole bunch of $$$$ into. Sorry for still qestioning it, I have few opinions to follow by.
#65
Call 1-800-988-4345 and ask to talk to Pete at Southbend. That man has been there and done that. His opinion is worth its weight in gold, IMO
I just wish he would make a McLeod style clutch with the 3 fingers. Haisley is the only one I have seen so far in the Street Master clutch. They shift like a single disk clutch.
#66
^^^^what he said. give peter a call. I have the 3600 DD and absoultely love it. Its not *too* stiff and i've back quite a few trailors with it. I think its very streetable. but see what pete says he'll set you up.
#68
IM NEW TO FIXING UP MY DODGE SO CAN SOMEBODY TELL ME WHAT IS (STICKS)?
ecbrewer2224
12-15-2008 02:44 PM
Megacab374
16
07-08-2008 12:08 PM
Out Back 4x4
44
09-10-2007 10:19 AM
YZ3500F
06-25-2007 10:38 PM
