help me diagnoss my fueling problems
my truck started acting up tonight, its a 06 2500 4x4 with a donaldson air filter and a superchips programmer,thats all it has.
what its doing is it just losing power and dying sometimes, and then other times it just dies out completely. (i was in a curve, and it just quit. talk about hard to handle with no power steering) Its throwing a code of water in fuel and fuel delivery error. also when you put it at wide open throttle on a take of with full turbo boost i get a really clangy noise from under the hood (almost like a broken turbo shaft. But the turbo is fine, ive checked it.) Ive put in a new fuel filter.
i would say lift pump if it was not for the noise that is why we use a gauge. try this first. the fca can be stickey add two quarts of dextron III atf and one pint 2 stroke oil to the tank you can fill the filter housing with atf before starting
tom creek
01-31-2011 05:06 PM
