Help!!!!! Have Fuel In My Oil.
I Was Driving Around And When I Stopped Somebody Said Your Leaking Something. I Found Oil Leaking From The Crankcase Relief Valve. I Took It To The Shop And They Said That The Injector Seals Were Probably Bad. So They Replaced All The Seals And Put On New Copper Washers. I Have Ats Stage 4 200hp Injectors. Drove It Home And It Filled The Cranck Case Again. Im Not Sure If The Head Is Cracked, It Has Been Fire Ringed And Big Valves. Maybe The Cylinder Is Fried? I Dont Know What To Do?
06 Mega Cab,ats Compouds 3000 & 5000,ats Full Billet Tranny,ats 5 Star Converter,ats Twin Cp3 Pumps,ats Stage 4 200hp Injectors,arc Flow Intake,snow Water Meth,arp Studs,smarty Tnt/r, Superlift Ladder Bars,fire Ringed And Big Valve Head,ats Copilot Lock Up, 35-12.50-20 Toyo Mt On 20'' Xd Monsters,
683 Hp 1374 Tq 13.3 @ 105.27 1/4 Mile Just Ordered Tst Powermax Cr, I Am Hoping For 12's
who was it that did the work ?? do they know diesels or/ CR's well ?
btw... I wouldn't drive it anywhere. Have it towed if necessary.
- cracked injector and /or tips
- connector tubes not seated properly
X2 on the cracked injector take the valve cover off and start the truck and let it idle and look to see which injector is leaking it will either smoke around the injector that is leaking or it will through fuel to the hood like mine did when that happened to mine. do not drive the truck like that
DTR 1st Sergeant
Other sources for this not mentioned above are a leaky cp3 seal (not likely unless you just did a R&R on it) and there is a little check ball toward the top of the injector body that is covered by the solenoid shroud. High pressure has a tendency to blow that little ball out sometimes and that will cause you to make oil.
Alpine Offroad And Performance. They Dont Know What To Do. They Call Ats Diesel For Advice. They Are A Bolt On Performance Shop. I Think I Am Paying Them To Learn. We Took It To Dodge And They Checked The Individual Injector Pressures And Said They Were All At 160ml. So Maybe Something Else?
DTR 1st Sergeant
It will shoot fuel everywhere if it is a cracked injector body, depending on where it cracked. It may just mist slightly, you may not see it at all if it is just dribbling up from a bad o-ring. If it is the check ball I described above, you may not see it at all. Of course, the cp3 seal you wouldn't see either unless you removed the cover and looked for it specifically. Sometimes these can be hard to trace. If it is a cracked tip, it is extra fuel washing down the cylinder wall and you won't see it.
it will throw oil everywhere if you rev it up but with it just idling it will not throw but maybe a couple drops but it will show which one is leaking i have had this happen twice once the injector would spray to the hood the other just smoked out around the silonid (spelling) but dont touch the injectors while running becuase there is a enough amprage there to kill you if you touch both posts on the injectors
Thank You For All Your Help I Really Appreciate It. I Am Trying To Get It Fixed For This Weekend. Ats Diesels On The Mountain In Denver. I Am Going With Or Without My Truck. Id Rather Go With It. Are Any Of You Guys Gonna Be There?
GlennRMK
05-24-2007 10:46 PM
Intercooler
06-04-2005 07:48 PM
