Help!!!! Got her back from ATS
Old 11-02-2006 | 11:51 PM
maddog madden's Avatar
Got the pick-up back from ATS, ran like a champ till i discovered the bolts that hold the pully to the crankshaft were loose andand the pully was about ready to fly off. I tightned them up ran fine till they came loose again. Are these sopposed to be "loc tite" on them? If so what color red blue?????
Old 11-03-2006 | 02:32 AM
PourinDiesel's Avatar
Are you talking about the vibration damper?
Old 11-03-2006 | 05:33 AM
Dodgezilla's Avatar
They shouldn't need any loctite on them. Maybe it was kind of cocked when you tightened them. I would suggest taking the belt off and then tightening the bolts. When I did my 03 I used a big long ratchet and hit it with a 3lb hammer to tighten them.......
Old 11-03-2006 | 07:48 AM
Torque the bolts to 165NM each with a torque wrench. Make sure you use something to keep the engine from turning over.
No loctite needed...just correct torque specs.
Old 11-03-2006 | 07:53 AM
Dodgezilla's Avatar
So, are you trying to say mine may not have had the right amount of torque with my procedure?!?!?!
Old 11-03-2006 | 08:32 AM
Probably not....
I don't gamble with critical engine part torque specs.
Old 11-03-2006 | 08:41 AM
banshee's Avatar
Surely you mean you don't gamble... I hope...
As another option, my FSM says 40 N-M plus 60 degrees.
Old 11-03-2006 | 09:04 AM
Oops...mistyped that one!
Old 11-03-2006 | 09:18 AM
Dodgezilla's Avatar
I didn't gamble with mine either. I hit it 3 or 4 times to make sure it was at least 40 ftlbs......
Of course although I really did do mine this way, you should heed the correct advise and use a torque wrench..... I'm just a rebel and like to do things my own way......
Old 11-03-2006 | 10:27 AM
Sloverado's Avatar
Another question about the Fluidampr. Can you guys get you belt on and off with it on? I couldn't get the belt on with the fluidamapr on. I had to loosen it up a little and tilt it then put the belt on then tighten the dampner.
Old 11-03-2006 | 10:32 AM
Nope. Had to loosen it to get the belt on.
Old 11-03-2006 | 10:39 AM
Sloverado's Avatar
Alright cool I thought mine was just being stupid.
Old 11-03-2006 | 10:44 AM
Ok thanks guys heres the plan
Plan A = PourinDiesel
Plan B = Dodgezilla
Old 11-03-2006 | 11:29 AM
Dodgezilla's Avatar
Hmmm, I vote plan B.....
So, how do you like the monster you just created? Looks like you went a little nuts there.....
Old 11-03-2006 | 11:47 AM
Luken's Avatar
Looks like he has a nice setup.
