Help finding Mid-Atlantic Diesel Performance
I have dealt with lloyd mills and Mid Atlantic Diesel Performance in the past but i cant seem to find their website. Any help finding their website would be appreciated. TIA,
Jordan
Jordan
Thanks madhat and Signature600, I figured that was the problem that i was having but i just wanted to be sure, I dealt with him before as he is a Formula 1 diesel dealer. Im pretty sure i have some leaky injectors or other related injector problems and i was going to contact him about seeing how busy Don. M is these days. Guess i should think about finding another F1 dealer. Thanks
thanks dodgezilla i saw the list of dealers on F1's website. I gotta figure out if the injectors are the problem or if one of the other things in my fuel system are the problem. Im having a hard start situation again and i can hear the lift pump come on but i havent been home to check the pressure yet. and i unplugged the fca and no change. It seems to run fine once you give it some juice but i have a feeling one of my injectors that wasnt bad when i initially had my new nozzles put on is leaking off. The only hope i see rite now is some wet spots on a couple fuel lines and it appears my connector tubes may need tightened up. Thanks for info about Tim barber.
Jordan
Jordan
Lloyd's a good guy and very busy. Not sure why his website isnt working. I tried it the other day to look for a custom part he sales. Give him a call. Leave a message and he will get back to you. 240-818-2973
Guys, read my lips....RUN AWAY!!!
I've dealt with him in the past, but after seeing what he's recently done to a fellow customer, not a chance anymore...
Chris
Chris
These forums are great for getting your name and business out to the public and they are also great for getting you thrown under the bus when there is a gripe to be made, legit or not. Lloyd has never been dishonest to me and several friends in dealing with him. I find it hard to believe he just out of nowhere picked this guy you are refering to and pulled what is being said about the situation.
