HELP, EGT's
HELP, EGT's
I went to the mountains this weekend and pulled my fifth wheel (40' toy hauler). My truck will go as fast as I want it to but my EGT's would climb over 1350 if I went over 45mph. What if anything can I do to keep them lower.
How high can the EGT's go before you have to worry?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
The best thing you can do IMHO is understand that there are limits to the superhuman abilitites of your vehicle, and just take it slower.
Other possibilities are a slightly larger turbo, Trans, valve body, torque converter upgrades, and a larger intercooler.
Cheers
Mike
The simple things will help. Intake and exhaust, a "TRUE" cold air intake would be my best advice, not any ol' intake system is a true cold air intake! I chose the PSM intake, with an Amsoil drop in filter and an AFE torque tube. I also did an MBRP muffler replacment. Nice sound, no drone while also towing my 40' Toyhauler. gOOd lUcK!
let'er breath! cold air in, hot air out!
more air = turbo
denser air = better inter cooler or chemical intercooling.
also , can do a cam change, wont actualy help egt by much, but it'll get cyl temps down, spool the turbo better, move more air.
more air = turbo
jmccart
03-18-2007 10:03 PM
jmccart
14
11-20-2006 06:45 PM
barracuda
08-03-2005 08:59 AM
