Help controlling EGT's.
I dont think its to hard but I ve done alot of them. On my truck I dont change the set up between straight water and even straight meth. I do a lot of turbos on gas engines and do water/ meth on them too to control detonation. I have run straight meth in the truck. I dont inject a lot persay, but I do run two jets, and a progressive map based system, with an adjustable pump pressure also. It basically gives you to much control, cause you can achieve the same thing several ways.
On a side note I ussually dont have to even run it on my particular truck due to its set up, but do see a substantial egt reduction using it. Esspecially passing or recovering on a long hill with 18k lbs of trailer.
In a day/night of a lot of hot rodding the truck I can use most of a gallon , (windsheild res) or in a 300- 500 mile trip. My only comes on over 25 psi. On a side note the windsheild res is nice cause you get the low light on the dash too.....
hontech2004
01-04-2011 03:47 PM
travelingman
01-15-2009 03:13 PM
uriahpick
01-09-2008 03:52 PM
qzilla
04-13-2007 08:12 PM
jmccart
14
11-20-2006 06:45 PM
