headlights
#31
Totally agreed. I bought the set from seller "HID World". I have bene buying from them for years and always loved their product! I will have to see if my "old" setup (the HID low, and regular high" still has the resistors all wired up so that they are plug and play. Either way, I will definitely be putting them in the classifieds!
#32
I run the Brite Box w/ Fogzilla, Factory Bilbs..., and 130 Watt 6" ProComp Driving Lights. With a toggle of a switch...I can have the Drving lamps click on and off with my Brights. Just like stock control, but I switch from low beams...or low beams with fogs to high beams, low beams, fogs, and driving lamps all on at once. I will "light challenge" anyone and I only have $250 or $275 in it.
Just another thought.
#33
You cannot do the relay mod on an 06 like you could with the 04...
...ither way I'll soon be able to run my fogs with the highs once my Bully Dog gets here. Brighter lights is nice though...
#34
#35
No, not that!
I'm talking bout the little "do it yourself" trick with the relays in your fusebox, that won't work with the 06's.
Also we're required to have daytime running lights up here north of the burner, can't get your little box for that either (if I'm reading your chart correctly)...
Just imagine your setup with HID's though!
Extreme Diesel
40
12-25-2006 11:23 PM
