head studs
Originally Posted by PourinDiesel
I have a hard time believing that a 12mm from anyone even made from cryptonite is going to surpass the clamp load of what your basic A1 14mm can offer.
After thinking about it a while, there are other things to factor in as well.
Like:
Head walk, block flex, extra stability offered by a larger bolt etc. etc. etc.
Like:
talk to doug at PDW, he spent along time working with ARP to get those high strength 12's made...and they are every bit as strong as the 14's. and for $1300 they cost about the same as buying 14's, then paying someone to machine the head and block to accept the larger studs, and you dont have to remove any material from the block which COULD potentially make it weaker
I dont need to talk to anyone.
The big power makers dont use 12mm's.
Sorry to break it to you but 800 hp with a single and nos is not big power.
Big power with our motors is 1400-1500hp @ 150lbs of boost on #2 Diesel and some water.
oh i thought you meant guys who do the work themselves...not the ones who drop a truck off at schieds with a blank check and pick it up 6 months later to start pulling. my bad mr. big dog, i didnt know
never thought it was the baddest out there. and as for spray...ill never use it, i dont care if i can add 300hp to my truck with the spray and have all kinds of bragging rights. if i ever use anything it will be water. but i'll also never make 1500hp or 800 for that matter.
Dont anything I say the wrong way.
The better 12's are great if you are wanting to stay away from going to 14's.
But most of the people needing the better 12's are on the bottle anyways.
12valvetom
11-27-2009 11:37 PM
dieselboy59
01-30-2009 03:57 PM
smokewagon
08-08-2008 09:54 PM
MikeThomas
05-11-2008 11:39 AM
jmccart
21
05-14-2007 11:47 AM
