Head Gasket went
Old 10-16-2008, 12:04 PM
  #31
jrussell's Avatar
Originally Posted by cquestad
It helps...problem fixed...as in the coolant is NOT going into the overflow.
But I have no idea if the head is lifting some...
Seperate deals....same results.
Opie's or anyones else's bypass is an inportant product to increase water flow around 5 and 6.
Can you please explain how this bypass kit increases water flow around #5 and #6?
I'm not trying to start a debate or anything...just curious. I emailed Opie a week ago or so and asked for details of his kit but haven't received a response yet.
Old 10-16-2008, 12:07 PM
  #32
cquestad's Avatar
The flow gets blocked off there by a "steam bubble". Since coolant is allowed a second exit from the head right where the problem is...it increases flow by the above said hot spot.
Old 10-16-2008, 01:29 PM
  #33
Hintz's Avatar
Go on CompD and read up he posted how it works and what not.
Old 10-16-2008, 06:35 PM
  #34
wap
wap's Avatar
What Hintz said, look under the sponsor section and click on Inteligent Engineering, there is a thread there with some good pics and info.
Old 10-16-2008, 07:21 PM
  #35
jrussell's Avatar
Thanks guys!
Old 10-19-2008, 12:29 PM
  #36
XLR8R's Avatar
Originally Posted by BossHogg
Does everyones bypass increase flow around 5 & 6? I am most likely going with the Lazar Smith BOE?
Kevin,
The BOE design incorporates a riser that gives steam a place to collect in away from the head even when it's "off", doubles the size of the coolant return circuit that flows through the hot side of cylinders #5 & 6 before either purge stage cycles, and of course doubles the coolant volume flowing around #5 & 6 when the setpoint limits of either stage are met.
Also, I don't think you'll need O-rings with your HP goal... but they can't hurt, either. (except your wallet! )
ted_pulliam
07-16-2009 11:33 AM
wildchild97
09-25-2007 02:44 PM
pred
11-20-2006 08:53 AM
drew03
76
02-06-2006 07:57 AM
Crimedog
10-12-2005 09:01 AM
Quick Reply: Head Gasket went
