he351cw wastegate mod?
ok i have searched and not found what i'm looking for...
do i have this right you just drill the wastegate hole out to 1" and thats it? With the housing off is there one dirrection better then the other to do this?
Thanks
Ceno
Thanks
Ceno
ceno let me help
when 12 volts is applied to the solenoid it opens up a port and bleeds some of the air back into the volute increasing the waste gate opening from 20 psi to 30 psi. remove the three o rings to prevent damaging them and cut the solenoid into about 7/8 inch above the base that mates to the turbo next cut the square part where the wrench go's deeper to make it easier to tighten up. i cut some more of the outer barrel off for looks but you do not have to. next remove any parts left in the center tube, you will be able to see all the way through the tube. tap the tube with a 1/8 in. npt. and install a 1/8 pipe plug. replace the o rings and install see pix.
AH64ID
12-23-2010 08:46 AM
sallyman1
02-10-2008 06:17 PM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
wannadiesel
38
09-29-2005 06:35 PM
