HE351 Turbo Swap info...
#271
I put a $.50 C-Clamp on my hose and I can see as high as 40psi if I give it enough fuel. With just my Van Aaken C3.2 box on high I see between 30-35psi depending on how long I keep my foot in it. It takes a long time to get to the 35psi mark. I just have the stock solenoid still in place...
#272
I don't have enough fuel to hurt anything on my truck. 35psi is as high as my truck will get with my current setup but that's if I turn my VA on high which I only did a couple times. You have a lot more fueling than I do so you may want to try the clamp but don't crank down on it all the way. Start with it about 3/4 cranked down and start testing and tuning....
Are you sure you're not adjusting your elbow the wrong way???
#273
You might be bleeding some boost past the solenoid. If you remove it you will see a bypass port in the compressor housing that the ATS plug seals. My 03 would hit 40 psi easily with just a Smarty for additional fueling.
#274
Well, the turbo and DP clamp both showed up today. The only part I am missing is the gasket for the turbo oil return line. Anyone have this part #? Now all I need is for the weather to cooperate, so I can git er dun!
#275
I got mine installed Friday. It is sweet! With the silencer ring removed, and combined with my JMB Perf. intake, it sounds like a freakin' jet plane cleared for takeoff! Pretty cool! I don't have my gauge install complete yet, so I'm not going full pulls or anything, but even so, I can feel a definite improvement. Since ATS decided not to send my plug for over 3 weeks now, we found a way around it by cutting the solenoid off the nut and welding a 1/8"NPT bung fitting on it, and atttaching the boost elbow there. Also welded the side transfer ports inside shut to prevent leakage around it. All in all, a very clean way to do it, and much cheaper than the $60 plug. As soon as I get the gauges hooked up and Smarty installed, I'll give you the complete story on it. Thus far, I'm very happy with it for such a simple and relatively inexpensive upgrade! Many thanks again for this thread (and site)!
#276
I'm picking one of these up for my '03 6spd, planning to run it with Smarty Jr and some mild propane injection for towing a 17k trailer.
I'm a bit confused on the blocking off of the passage in the selonoid plug. If I'm totally disabling the wastegate anyway(spot weld or turn buckle) do I need to worry about it?
Is it safe to tow 17k with the fuel the Smarty Jr will put out and the wastegate disabled?
Thanks!
Thanks!
#277
For the WG, you will want a plug for the solenoid hole, ATS sells one. That will disable the WG, nothing else needed.
You should be fine with the Jr and towing without a WG. I have seen that the WG opens on its own about 55psi of DP, so its a lot of DP, but not too bad.
If you find your getting too much boost or DP you can easily make the WG operation again with an adj boost elbow.
#278
Ok but if I didn't want to buy the plug and wait for it to arrive can I just pinch off the waste gate line and be done with it or do I need to also plug off the holes in solenoid?
#283
John at ducu916@hotmail.com makes a replacement plug drilled and tapped for a boost elbow. Comes with oring ready to go.
#285
Adjustable elbows are hard to adjust. I put on the elbow that came with an Edge EZ. My boost now will just goes over 35psi instead of much higher. It has a very small hole in it.
