Having Smarty JR Issues
I'm trying to put my smarty jr in and I keep getting a code " error cant read software" all I can adjust is TQ and TM. I've done the latest up date to 5.13v. what could be my problem? My truck is a 2005 quad cab cummins 4x4 auto. Help please
Try and get in contact with Bob Waggoner (sp). I hear he has an answer for everything Smarty related.....afterall, I believe he does work for MADS Electronics (Smarty).
I took truck to the dealer to make sure it was all stock, they said it was stock. I tried to load up the Smarty when I got it, I bought it off a DTR Member it still had the old version in it and wouldn't load up same error came up on the screen so I loaded the new version in hopping to fix the issue and still have the same issue.
888-225-7637 or 253-735-6281
bob-wagner@msn.com
Sounds like you do need to call him (especially considering the "dealership thing"). Bob's a great guy....
Good luck!
bob-wagner@msn.com
Good luck!
Bob is a nice guy, turns out my truck is a handfull smarty wont work on out of the box, he is sending me a fix. so hope to have some juice soon.
Here is a update...
I finally had the time to fix all issues and got the new info loaded plus the smarty jr loaded and the truck runs like a champ now, even runs smoother. I was getting 650km to a tank of fuel now I'm getting 900km to the tank which I think is well worth the money for the unit. SW3 TM2 TR3
I have a Quadzillia modual that plugs into the wire harness, is this something I could stack with the smarty jr.?
Thanks Regert
Thanks Regert
do you know where Quadzilla is located, what state? I'm in Canada so not sure it's worth the shipping for the power gain off the unit. Not sure if it would even add power stacking with the Smarty Jr.
Might just put it in for the drive home from work and see what she does, I'm only 30km drive.
Sorry guys, my bad. I just grabbed the box and its a 2018 Dr. Preformance predator 111. NOT a Quadzilla......
Will this work good with the smarty jr, I've been searching it and some people like it and some don't. any info would be nice thanks
DTR 1st Sergeant
It will work with the jr. However, whether you want to is the question.
The Dr. Performance is a good quality unit. However it is a very aggressive pressure box. This has the tendency to shorten injector life.
The recommendation would be to leave the Dr. Performance hooked up, but leave it turned off unless at the track or dyno. Don't run it all the time.
