had to send in my xzt!!!
I had been having problems with my quad xzt box making my truck act strange. I had checked all of the connections and no problem. I finally plugged in the bypass and the problem went away. So I came to the conclusion that it is the box itself. I have been running with the bypass in for 2 weeks now and have not had any problems. I waited for along time for quad to answer me on how to get it fixed and never got a response from him. Larry told me to just call quadzilla customer service. I did so and I ended up having to ship my box to them and am now waiting to find out what he finds. I am getting very disapointed with quad since I have only had it for about 2 months before I started to have problems. It would make my truck surge going down the hiway and not idle down when I came to a stop. If I bliped on the throttle to get it to idle down I could make buildings dissapear in the smoke!!!!! And it would idle down but run extremely rough. Then when taking off I could just barely touch the pedal and it would practically smolder the tires. I have now been without my box for 3 weeks and I am yurning more power for pulling my trailer. Does anybody have any suggestions or has anyone had the same problem. I have heard of some having problems with the connections which I had the first time I installed it but never had any since.. It just seems like the box went bad???
Mine works fine, talked friend into ordering one for his 2004.5 and helped him instal it last Friday. Well when I turned on the key to verify the box it blinked the wrong code. Code was for a 2004 unit which is different thant he 04.5. Called and immediatly was informed not to start unit and that Quad would send out a call tag immediatly and when thay got the box back they would check it, reflash it if necessary and immediatly ship it back. Asked about sending unit out now and they offered to charge on credit card for 1 and when the wrong unit was returned to credit card with returned unit.
Hopefully it will be here Wed or Thursday. So far I have never had any problems talking to someone (as long as it was during normal business hours) and this seemed more than fair. The person at Quad, Jerimie I think, was more than helpful and seemed to be surprised that this was the wrong unit as all the data on the labels indicated that this was the right unit. Aparently someone at Quad goofed, either by labeling it wrong or flashing it wrong.
At least they were more than willing to take care of it as immediatly as was possible.
Don
Don
I also had problems with the XZT. 2 diferent boxes and 3 diferent wiring harnesses did not solve the missing problem. The dealer's diesel mechanic could not find anything wrong with my truck. So I had to request a refund. It is a big mystery why on most trucks the XZT works fine, but on others like mine they miss and almost shut down. I wish the problem could be solved, because I want the extra power and a little more fuel mileage also.
Bill
Bill
I've had mine on for about a month and a little over a thousand miles and I just keep smiling. Quads service is the best I've dealt with also... so don't give up just yet.
Tony
Tony
Re: had to send in my xzt!!!
You can ask the tech guys what was wrong and they will tell you. I will probably not see it myself unless something weird happened. It is not impossible for a board to fail, but it is very unlikely. I will say in your case it sounds like one of the IC parts broke and the lower part of the map that is controls went AWOL.
Bills problem was different. Nothing would work on his truck, no matter what. I am at a loss on his truck? I think he should buy an EZ or Ramifier and see if he has the same troubles?
Quad
So it can happen to all of them...
Good luck....
Guest
Posts: n/a
I was having problems with the standard X-zilla on my truck and we tried all kinds of things with mine(thanks for the effort Quad!!) and it just wouldn't work. I believe that mine just didn't like the added pressure so I ended up having to switch to something different. I went with the Juice w/Attitude and my truck works great!! May be worth looking into for you also WA4SLC. No offense to Quad as he has a great product and great customer service I just know how frustrating it can be to not be able to make something work so that's why I made the suggestion.......
Nice rollers
U2... I like those wheels and rims. They look sharp on your truck. Maybe when mine wear out I just might look into something similar.
I hope to have some pic up soon...
Catch u later
Catch u later
Guest
Posts: n/a
Re: Nice rollers
Catch u later
Catch u later
thanks for all of the replies.. I will let you know what happens!!! I had a juice w/attitude on my fraud and it was a pain in the butt to get installed and removed everytime I had to go to the *******. which was about once or twice a week... Thats why I went this route this time. I was actually looking for a plug and play "hypertech" but after finding out that the dealer can find it in the computer after being removed sent me looking elsewhere to quad!! Inexpensive and good power and mileage as well as easiest to install. It blows my mind but So does 2 intercoolers in 200 miles.
Clucker
01-01-2009 10:28 PM
sCreamin400
11-02-2008 01:46 PM
ddestruel
05-24-2005 08:55 AM
