h2o/meth installed w/ pics
Old 07-07-2007 | 02:33 AM
gus's 03's Avatar
i did the install last weekend, mostly in the dark so sorry for lack of detailed pics...
id say install time was about 3 hours, mostly spent fighting with the washer fluid bottle.
i installed a snow stage 2, i used 1 large nozel, one small (650/375 ml if i recall. )
controller got mounted in the typical top of the fuse block.
manifold came off drilled and taped for the 2 nozels and boost port.
chalange was where to mount the pump.. turns out theres just enough room to tuck it into the body mount...
worked out good. keeps every thing protected, the line from res to the pump is short and gravity fed, every thing is in easy access.
results: i used wally world winter blend fluid. it took some tuning to get rid of the rattle, and you can tell its not a quick clean shut off, but overall im happy. i did my best to load it down to see egts , ive got a hill about 3/4 mile long thats steep even by local standards (im guessing almost 8%). it seems like i saw almost a 200 deg drop , but bust climbed a few psi at the same time so that might have been a contributing factor. definetly feel the change.
only real gripe if you wana call it that is that for extended use you gota have a big tank. it comes w/ a 2 qt tank, the washer res is almost a 1.5gal, it go's fast.
im thinking if i was looking strictly for egt relife towing, id use 2 small nozels and strait h20. prob see as much or mayby more drop id think by not adding meth but droping nozel size.
i plan on welding in a bafel in my tool box and converting it into about a 10 gal tank.
Old 07-07-2007 | 02:45 AM
WUnderwood's Avatar
I would use some Goop on those threads, just my opinion
Old 07-07-2007 | 02:51 AM
gus's 03's Avatar
i did , i just didnt go overkill. enough to seal, not enough to make a mess, or worry about plugging up stuff down the line. figured that was something i wouldnt need to put in the wright up.. then again comon sence isnt all that comon any more...
Old 07-07-2007 | 09:11 AM
jrussell's Avatar
If you're looking for a larger tank, US Plastics sells the same 6gal (or is it 8gal) tank that Snow and Coolingmist use. They charge over $100 for it and you can buy them for about $20 with the cap from US Plastics.
On my last truck I installed the pump and tank inside the toolbox. Worked great and kept the pump clean and dry...but most importantly keeps vandals from spiking your solution.
Old 07-07-2007 | 09:25 AM
wap's Avatar
wap
Is that really an issue? Man I never would of thought that someone would want to tamper with something like that.
Old 07-07-2007 | 09:52 AM
jrussell's Avatar
Yeah my buddies here in Utah think I'm nuts, but I grew up in S. Florida where anything not bolted down will walk away. The odds some punk would even know what it is are pretty slim, but it only takes once to really mess you up.
Old 07-07-2007 | 11:35 AM
trik396's Avatar
I'd be worried about shooting meth without studs... That's just me. Straight water would be safer and cooler egts. Otherwise, great thread and good job. I just got my Devilsown setup, waiting to install....
Old 07-07-2007 | 12:32 PM
purduepurdy's Avatar
The whole idea of water compressing scares me, saw an engine burn up a head gasket once and sucked coolant. Good times! Ill probably look into a kit later on though, seems everyone likes them and its cheap.
Old 07-07-2007 | 08:54 PM
johnh's Avatar
i can't believe it! no trust.... i'll bet you even take your keys out at night.
Old 07-08-2007 | 06:31 PM
XLR8R's Avatar
Shurflo doesn't recommend using thread sealant or teflon tape for their pump housings - they're made with a thermoplastic designed to positively seal at system pressure with "dry" fittings.
Old 07-09-2007 | 10:44 AM
tristan21's Avatar
Im gonna buy one from a dtr member but was wondering what the cost is to upgrade to a stage 3 from a stage 2? Anybody?
Old 07-09-2007 | 01:12 PM
dodgezilla04's Avatar
after towing at montana altitude, i'm gonna have to do something about the egts. the turbo just wasnt enough on its own.
water is probably gonna be my solution
XLR8R
34
02-28-2008 09:46 AM
XLR8R
15
01-19-2007 07:06 PM
tristan21
12-28-2006 08:01 AM
blackdiesel
19
11-14-2006 04:54 PM
BigBully
02-16-2005 07:19 PM
