H2O Meth
Old 09-27-2006 | 10:02 PM
XLR8R's Avatar
H2O Meth
Anyone run water/meth on a '04.5+ common rail with a fueling box?
Specifics on jet sizes, water/meth psi, boost pressures, etc. along with power increases and EGT reductions...
Old 09-30-2006 | 04:10 AM
griggs43's Avatar
i got an 03 with aditude and som change
i got the snow kit its great
very versitial i was talkin with the guys from snow and they said to run th 675 fogers if i want power turn the start settin off and turn the full setting down in psi
i mainly us it for power
with that set up i run about 100 cooler
when i had it diled in for cooling i saw as much as 250-300 degrees cooler
just off of washer fluid 20% meth
at the track i run 65/35 mix and it runs like a raped date
i love it
hope that helps out
matt
Old 09-30-2006 | 10:16 AM
XLR8R's Avatar
Thanks Matt,
What were the numbers in the power department?
... not really sure how to quantify a "raped date" - other than with 911 !
Old 09-30-2006 | 11:42 AM
973604x4's Avatar
I'm also interested in this...pleae keep sharing experiences. I am learning the Snow kit is the best kit??
Old 09-30-2006 | 02:21 PM
omaharam's Avatar
Here is my experience - see my sig for my truck details.
The instructions in the kit say you can use both 675 injectors with the pump turned all the way up if over 450whp. However, Snow actually installed this same set up on a bone stock '05 in an issue of Diesel Power magazine. They dynoed with good improvements in hp and torque. I decided to install the two big injectors. I can run the juice on levels 1 and 2 and actually feel a seat of the pants difference. On levels 3,4,and 5, I can't really feel it. The truck runs fine when empty, however I have never seen an egt reduction. Back in July, however, I made a trip over the Colorado Rockies towing about 9k pounds and was completely dissapointed and frusterated. If I had the gain **** turned higher than about 10%, the truck would run horrible and dump white smoke. I tried running a higher mix of methanol and that did not help. I called snow and they said I was right on the line to be using both big injectors. I mentioned the stock truck that ehy did an intall on and that mine ran fine unloaded. One guy told me to turn the pump down, and another guy told me to leave the pump and replace one of the big injectors with the smaller one. Here's the thing. I can tow my camper around Nebraska just fine with no issues, so the only way I could test it, is to drive far enough to pull some big hills. Consequently I haven't done any messing with it. The whole reason I bought it was to reduce egts while towing. I have seen no egt reduction, on any setting, towing or not, with any of the mehtanol mixes I have tried.
Here is my conclusion. If you have the time, patience, and a place to test, try it. Some people claim success. Just know that it is not a bolt in and go - at least not for me. I would not spend the money again. I would put it toward a turbo.
Old 09-30-2006 | 06:33 PM
XLR8R's Avatar
That's my impression as well...
Old 09-30-2006 | 10:25 PM
emfc_22's Avatar
hey guys i am going to get all the lniks together for the kit on my truck. you can get the same pump that flows 100psi that snow uses for less than 90 bucks and the injectors for around 2 bucks a piece. and the syliniode and boost switch for 30 bucks all together. other than some clamps and hose from the hardware store that is all i have in it. no dyno number though, and no egt gauge either. but when it comes on it comes on hard. you can use 20 below windshield washer fluid mixed with one qaurt of alchol from wal-mart in the band-aid isle and it makes the 65/35 mix or so for around 3.00 per gallon
Old 09-30-2006 | 11:48 PM
973604x4's Avatar
sounds awesome...fill us in!
Old 10-01-2006 | 01:57 AM
XLR8R's Avatar
Wow - that's the gold mine we were looking for - give us the facts so we can repeat and you'll be our hero!
Old 10-01-2006 | 09:46 PM
emfc_22's Avatar
here it is www.mcmaster.com go to catalog page 1939 get standard nozzles that flow 4 gph @ 100psi i run two of them but some run one. same site page 420 part number 7876k81 is the solenoid i run and it works great (if you run a boost switch to turn on and off the system for you, you can run a led inline with the power to the solenoid so when it opens the light you place in the cab will come on letting you know if it is on or not, also you can make sure it is not on when idleing). the boost activation switch came from http://www.enginerunup.com/parts/boo...tch/prod_3.php i think a hobbs switch from napa would work also. and the pump that runs it all http://www.pro-spray.com/sprayer_pumps.htm it is the 1.4 gpm @ 100 psi this pump will pressurize the line then when you shut the soleniod it will automaticaly shut off then come back on when it is opened and also won't burn up if it runs out of water. as for the tank i just mounted everything in my toolbox in the bed and cut a hole in the top of a 5-gallon can the size of the 3/8 hose to the pump and left the breather on the can open so it can drain easy. well there it is a big water/meth kit for under 140 bucks
eric
Old 10-01-2006 | 10:58 PM
XLR8R's Avatar
Awesome, Eric!
Thanks!!!
Old 10-01-2006 | 11:17 PM
973604x4's Avatar
Originally Posted by XLR8R
Awesome, Eric!
Thanks!!!
i remember you were joking with robert about turning the smarty up to 9....well i have mine on 9 right now! its lots of fun.
anyhow you gonna attempt this h20/meth??? i'd love to see it....heck if you can wait til this semester ends, i'll personally come help you. i'm from midlothian so you aren't too far from home.
Old 10-01-2006 | 11:30 PM
XLR8R's Avatar
Smarty #9 with Quad's Boost Fooler? Sounds like a blast!
I had the water/meth system designed, and eric's info reassured me that I was right on track for the specific parts... I plan on fabricating it before the end of the year. I'm going to make a SS tank where the airbox used to be - hoping for at least a 3 gallon capacity.
Of course you're welcome to come by the shop whenever you're in the area and I'm out there.
If you're going to Baytown in a couple weeks, I'm sure we'll see ya there!
Old 10-02-2006 | 08:23 PM
emfc_22's Avatar
soon as i can find the cable to my camera i will post photos of the kit on
Old 10-02-2006 | 08:47 PM
XLR8R's Avatar
That'd be great!
