Growing 2100 RPM drone
Well I got a Donaldson 34" muffler and put it on about a week after I got my truck in June. I had no drone and I loved the thing to death. I now have about 12000 miles on it and the drone at 2100--2200 RPMSs is killer. Sadly it is almost impossible to avoid that RPM range because it really likes to stay trhere when you are pulling something. I find myself letting off or flooring it to get it past that crappy area because it hurts my ears and everything in the truck is vibrating. And it seesms like it just keeps getting worse. I never did have exhaust hangers added, and has resonated exhaust tip. I strapped some 2" angle iron to the pipe to no avail. I am thinking of trying some real heavy rasp bar out of a Deere combine we have out in the shed and seeing if that helps because it will be a lot more mass than the AI. I want to fix this without chasing a bunch of wild geese...
What should I do?
What should I do?
bin there tried that lol, had a mbrp, and a magnaflo, drone was insane pulling, had to go back to factory muffler no cat, this muffler flows very well, do a dyno pull with the noisey one then do one with the tock muffler, very close, and the same for the egts, that was my experience, did not want to go back to stock either but had to or will be wearing a hearing air by 40 lol.
A quick/easy option for you may be to put a small resonator in-line before the muffler, just after the downpipe. I have the same muffler as you. I'm over 10K and I have no drone issues to speak of. However, my issue is that it has gotten progressively louder as I have bombed the truck. Opening up the exhaust side with the ATS manifold, bigger turbo w/ bigger turbine opening, Banks DP, etc., has all contributed to the exhaust being much louder than when it initially went on (it was sweet back then).
http://shop.airflowonline.com/Mercha...ategory_Code=R I have one of these awaiting the new turbo to arrive. Plan on putting it on at the same time. These run $40 to $50 if you pick it up locally at a muffler shop or semi repair facility. That web site is expensive. Just cut out a section of pipe with the sawzall, and clamp it in with 2 4" exhaust clamps. 4" exhaust pipe slides inside each end of this thing. Easy stuff. Just think'n out loud.
So you think a resonator is the way to go then?
I had that as one of my ideas and
Also maybe going to the 51" Donaldson
Rasp bar instead of angle iron
Hangers on the new muffler to help eliminate some vibe.
Any combination of these things
WHat exactly would the resonator achieve do you think?
Originally posted by Strjock81
So you think a resonator is the way to go then? WHat exactly would the resonator achieve do you think?
The trick with clamping angle iron to the pipe is to add weight on long, straight stretches of pipe to effect the vibration, hopefully effecting it for the better. If the angle iron didn't help, I suspect rasp bar won't either. You don't want but so much weight hang'n under there. If it is free though, I'd try it.
If you decide to try a resonator, make sure you report back. Lots of folks here with drone problems that could benefit if it takes care of it.
I should have mine on this coming weekend, or mid week next week, depending on when the new turbo gets here. No drone issues to report on, but I can let you know exactly how it effects what I've got going on.
That was long. I talk too much.
The idea of using a resonator or Aeroturbine far forward in the system is to change the frequency of the exhaust and there by move the drone out of your normal operating rpms. Hopefully it can be tuned out completely by doing this.
Forest Nearing, talk to me about the sound deadening! spinlocker@yahoo.com
RockcrawlingTJ
05-20-2007 03:16 PM
morkable
37
09-21-2006 08:14 PM
big red psd cc
02-03-2005 05:25 PM
