Got new tranny in but doesn't feel right?
did you go through all the gears a few times before you tried to move the truck, you have to make sure all the air is out, plus who ever put in the trans. needed to be extremely clean or you can clog up the passages in the plates.
But that's just dropping the pan right?? or do they pull the Tq converter and everything?? I could have sworn Ty told me when they did his it took 21? but Im loosing it too...lol... I see If i can find that post....
Just put 16 qts in my killer KH special 47RE today. It was doggy for several minutes of driving. Getting air out and frictions seated. Billet 3 clutch TC is a horse.
2000 3500 DTD
2000 3500 DTD
My trans was pretty tight when new (i dont think as tight as yours), but it loosend after breakin...and i do have a smarty, that could be the difference....
I didn't notice any real loss of low end power with mine. Dave put a fairly tight TC in mine and I did notice that right away, but only because it drove so much better. Definitely didn't take more power to make it move.
I went back and looked at my receipts when I installed the tranny. I bought 18 qts. If I remember correctly I bought a couple more to top it off....
If I put my Smarty on 0, I don't think I could pull an old lady in a wheelchair.... my truck will just not move... it takes the truck forever to reach hwy speeds..?
So far I think my tranny is shifting better with the Dextron III and Lube Guard. I have been able to drive around with my shift enhanser on
Daily, instead of Tow to eliminate the 2-3 flare/cutloose. My temps stayed where they were with the ATF+4.
It sounds like your VB's not puttin out the correct pressure to ingage. Did you also purchase the VB or using the stock one?
