Got my Edge Juice... wheres the juevos and the smoke?
8mpg, I have been testing the j/a for 06 and the biggest difference ive found is , level 5 w/ low boost on 5, and my defuel for slip ( in the tranny setup mode) off. Lots of throttle responce frombottom to top. I raced a built focus zx3? on the freeway from about 75mph with those settings, needless to say, I blew his coffee can off his exhaust. First CTD and love everything about it
My Juice will belch some pretty heavy clouds on level 5/5, especially while towing. Right now I'm running level 4 for just driving around and it works well. I was running 3/3 and it smoked a little. I need to get rid of my BHAF and get something better though. I think it is definately restricting my intake.
Originally Posted by 8mpg
See..i dont get it. My stock truck will smoke just a tad at full throttle..the level 5 does about twice as much but its still not much. Im used to bullydog extreme smoke.
So I said that to say this - your truck for some reason is reacting differently to the Juice than mine. I got to much smoke IMO. I am talking thick, black smoke, that just sits in the same spot and doesnt move. I was at a gas station the other day and a friend of mine wanted to see the smoke so I built some boost and launched about 30 feet. Circled around the lot and came back and parked in the same spot and the smoke was still just like - laying there - I couldnt even see through it.
Mine was the same way with Edge. My TripleDog will blow smoke like a coal train. Edge was always a good long puff and that was all. But mine did make good power. From a 70mph kick the Edge was stronger. Other than that I like the TripleDog power better.
I was really thinking of switching...but not after that TDR post.
I guess I better go over to TDR and see what is going on. As for switching once you get used to the Edge I am sure it will be fine for you. They both make alot of power. I enjoyed mine when I had it.
I have read a couple posts of people that have had warranty items denied due to downloaders.
Just thought I would throw in my experience with my J/A. I didn't get smoke either and on level 5 I could not put low boost over 2 without getting what felt like a miss in a gas engine. I decided to replace my in line pump with a higher pressure pump and the difference is unbelievable. I no longer have the miss and there is plenty of fuel to get me throgh 5/5 and there is smoke. And on that note, the smoke is nice but that is just "power you can see" as I have seen several times.
So as you can see, my engine has acted different than most here and now it has been improved with the help from a new fuel pump.
dieselTrain
06-17-2006 04:22 PM
razor6
22
01-20-2006 03:43 PM
ataboy9026
12-28-2005 05:06 PM
