Got my AFE super stock dry filter
It's Huuuuge, capital 'H'. Oil-free, same shape as the new K&N 3-D stock replacement filter.
This, along with a gutted stock intake, cool tube, or homemade torque tube, will surely flow just the same as any full intake system, while retaining the stock airbox. Total cost for the drop-in including shipping was $74.
I have pics of the AFE compared to a stock filter, and I'll post 'em up when I get home today.
Ive been running that setup minus the torque tube for about 4 weeks now and i can say that it moves some air. I have not found any literature about the micron filtration specs.
If I went with this filter and no airbox mod or torque tube(stealth mode), do you think it would it be enough along with my mbrp 4" exhaust and a mild programmer like the quuad xzt? Will I be able to hear the turbo whistle?
As far as the dealer's concerned , for warranty issues, I want to keep a very low profile(for now)
I think turbo whistle is all about geting rid of the air guides in the intake tube. A filter by itself won't make any difference. If you gut the intake, there will be turbo music galore methinks.
but I really doubt a dealer would void a warranty for an intake but stranger things have happened
I strongly disagree that it will flow as much as an open-style intake for two reasons...
1. The stock box itself is, by design, a huge restriction.
2. That drop-in filter has much less surface area than a Stage II AFE (or similar filter). Less surface area = less air flow.
It's definitely the sweetest drop-in replacement filter I've seen, but drop-ins are always going to have certain limitations which prevent them from flowing as much air.
What are you basing this statement on?
I understand what you're saying about filter surface area, but I think one of two things is true here:
1. The drop-in does have as much filter area as the full system, or
2. The drop-in may have slightly less than the full system, and not enough to make a tangible difference except maybe at extremely high power levels.
This drop-in is bigger than it looks in the picture...
The only remaining obstruction in the stock intake system that sets it apart from an aftermarket full intake are the baffles in the intake tube.
One last thing: how do you know that the whistle is due to your filter and not the intake tube? Your whole system is open from filter to turbo.
Okay, you have more experience with that so I'm not going to dispute that.
In regards to the box: I'm basing that statement on a comparison of an AFE full intake system, which, although it seems more open, it is completely enclosed and only takes air from the same place the stock box draws air: the stock intake hole in the fender.
The other main difference is size. Trust me when I say the filter with a 6" opening on the Stage II is MUCH larger than a drop-in could ever be. It barely fits in the larger AFE box and will only fit when crammed in at just the right angle. Not trying to sound negative towards this new filter, because I think it's the best option for anyone keeping the stock box. I just wanted to point out why I thought it woudn't flow as much.
Bweb91
01-04-2008 10:57 AM
Farmer Davis
08-21-2007 12:22 AM
darrenb
21
04-09-2007 04:56 PM
darrenb
02-13-2007 10:46 PM
