Glacier Diesel Walbro kit
Location: Smith Valley, NV (sometimes Redwood City, CA)
I just finished installing my new Glacier Diesel Walbro kit. This is a top quality setup. Well thought out, simple and should end the whole lift pump problem. I'm really glad I bought the kit instead of working through it piece by piece. I took my time and spent about three hours on it. I was going to drop the tank and do the vent mod too but I decided to put that off till later.
The pump is so quiet that I had to listen under the truck to hear it and there was no problem with air in the lines. Why didn't Dodge do this? Thanks Richard.
John
John
I still haven't heard why a lift pump is such a big deal for CR trucks, the Duramax has CR and does not use a lift pump, just the internal pump inside the injection pump. So why should Dodge need a lift pump?
John
John
wap,
Pricing for the '03-'04.5 trucks is available thru the link in my signature and I should have '05 system for your truck available shortly.
Richard
The Dodges will not run without the lift pump functioning properly. I think it's a pressure sensor or an electrical resistance change that signals a problem and the computer throws a code and stops the engine. Also, the CP3 won't draw fuel through the existing fuel pump. If all that is eliminated the CP3 will get less fuel and run dry sometimes while pumping the air out to get fuel. And while the engine is running there won't be an excess amount of fuel in the pump for cooling.
I guess Chevys don't use the lift pump. That's not necessarily better and ours are not designed to run that way. The old twelve valve mechanical pumps may be the best of all.
I may not have all this right, someone else can chime in.
John
Originally Posted by Reaper
Gypsyman,
Will the '05 kit your working on also work on an '06?
Thanks!
Thanks!
John wouldn't let me tear the fender liner out of his brand new truck to confirm my suspicions for some reason. Has anyone confirmed the new location of the '06 fuel pump relay?
John
John
Sorry for the delay. Had some turbo work that had to be taken care of. I ran my own flow test and the charts posted online are dead on. The 391 at the provided 17 psi is at 50 gph and the 392 is at 70 gph. The difference is that we're getting the entire gph output right to the inlet of the CP-3.
As you probably saw in the other thread Lloyd is holding mid 20's with a Stage 2 CP-3 and a single 392. For the guys that really want to get crazy with flow and pressure I'm going to work on a twin 392 system that will allow 40 to 60 psi at the flick of a switch but more sane pressure levels for daily driving.
Richard
Richard
