Georend low stall T/C questions
Old 03-10-2009 | 07:58 PM
HIGHGEAR's Avatar
The other day I did some pressure test on my transmission. On one of the test, I checked to see when my T/C was grabbing. My engine idles at 750 RPM and the T/C starts to grab at 800 RPM. Is this normal, or will this hurt the tranny any. I have a 900/400 T/C. Thanks
Old 03-10-2009 | 09:02 PM
Mcmopar's Avatar
What do you mean the tranny starts to grab? That T/C should start to apply power near that RPM, the higher the HP the higher the TC will start to "grab"
Old 03-11-2009 | 06:17 AM
HIGHGEAR's Avatar
What I'm trying to say is that my pressure guage starts to rise at 800 Rpm as I'm starting to accelerate. With my other Georend transmission the guage didn't start to rise until about 1200 rpms. Just trying to find out if this is normal. Thanks
Old 03-11-2009 | 10:06 AM
no_6_oh_no's Avatar
What port are you reading pressure from?
Old 03-11-2009 | 10:38 AM
HIGHGEAR's Avatar
The one on the passenger side in the middle no 6 oh no.
Old 03-11-2009 | 03:28 PM
no_6_oh_no's Avatar
That would be line pressure you are reading. It should start to rise right off idle and should be maxed at 1600-1700 rpm's generally. Depends on what PR valve and setup on the VB was used.
Line pressure won't effect when the TC stalls as that is internal to fluid flow in the TC.
flyingd
17
07-11-2017 12:13 PM
Minwy
02-17-2008 10:59 PM
TXGREYGHOST
37
02-19-2007 02:18 PM
inline6power
14
02-07-2007 07:58 PM
JD730
08-02-2005 12:33 PM
