Gauges chattering and sticking...
Im running DiPricol gauges. Fuel Pressure 0-30 and Boost 0-60.
Im getting an annoying buzzing / chatter from the FP gauge. Its intermittent and depending on rpm, it will change frequency. Im thinking it may be the isolator going bad or either low in antifreeze. Anyone with the same issue? I have the cheapo zinc isolator and its like 3 years old... should I upgrade to a better isolator?
With the Boost... the boost hangs up at zero. when im driving it stays at zero until I physically hit the pod and then it unsticks and reads normaly until I let the needle get down to zero again. Any thoughts?
Your fuel pressure is a result of pulsing from the injection pump. Place a snubber (tiny shut off valve) in line with your tubing and only open enough that the pressure is read on the guage.
Where are you pulling your reading from? Are you using an isolator?
Not sure on the boost issue. Sounds like you need to get the boost gauge replaced.
I pulling a reading from the injection pump input side though a braided line which feeds into my Isolator then to the gauge. I have the isolator filled with antifreeze... maybe its time to top it off again?
Ill check out the snubber... thanks!
Huntsville 3500
07-11-2009 06:43 PM
Duallydog
11-12-2006 08:36 PM
